05-05-2015, 11:46 AM | #1 |
Anyone use 3m tape for trim instead of clips on a square fender c-10
I run a small paint and restoration shop on the side and I am putting together a 73 C-10. This truck didn't come with a trim package but now my customer wants to add the side trim. I really don't want to drill the holes for the trim clips because I have most of the parts painted already and I fear that he may change his mind again after its installed. has anyone used a double-sided tape on the aluminum trim? Will it hold?
05-05-2015, 12:25 PM | #2 |
Re: Anyone use 3m tape for trim instead of clips on a square fender c-10
It ought to be fine. Most of the trim on the later trucks was held on by the double faced tape. So I wouldn't have a problem with it. Jim
05-05-2015, 12:54 PM | #3 |
I installed my lower moldings with 3m tape and it has held up for a year with no problems
05-05-2015, 03:30 PM | #4 |
Thanks for the replies, I may give it a shot and see how it holds up.
05-05-2015, 09:13 PM | #5 |
The only one that bolts on that I remember is the back corner pieces, and they are made of a different material. Jim
05-06-2015, 11:28 AM | #6 |
One thing you want to do is make sure the mouldings are clean and use an adhesion promoter like this http://www.amazon.com/s/?ie=UTF8&key...l_11r90huyfr_b
If the paint is near fresh, don't use it on that as it will "bite" into it pretty good. Which is fine if it's ONLY where the moulding will be installed but if you drip some on the paint it will mark it. But use a quality tape, there are different colors and qualities get a pro-grade one like this http://www.tcpglobal.com/MMM-6386.ht...A#.VUoxK_lViko And also, a dab of window urethane at the ends is a good idea too depending on how big the moulding is. But a tiny dab of urethane will be added insurance. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
05-06-2015, 05:54 PM | #7 | |
Thanks again! |
05-07-2015, 12:42 AM | #8 |
I'd like to know how well this works. We are about to install a complete molding kit on mine and I've wondered the exact same thing. When are you planning to try this?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
05-07-2015, 01:04 AM | #9 |
The hard part is if there is enough surface area on the moulding to put he tape. If it's a metal moulding with the slot for the "T" moulding clips to slide into, that leaves just the little strip of metal along the edge for the tape, that may not be enough.
Then the other issue, this is a biggie, the moulding has to perfectly fit against the body in it's entirety. And that's not easy with a metal (aluminum, stainless, what ever) because the studs or clips are what pulls it into place, twisting it, flexing it to fit. If it doesn't fit perfectly you may be able to push it into place but it will be fighting to pull off every second of it's life after it's installed. It can very easily pull up away from the panel be damned how good it's taped on. The tape is foam, and it can pull apart with the moulding pulling away from the body. So the fit of the moulding would be of upmost importance. Brian
05-07-2015, 02:53 PM | #10 |
I think i am going to cut some aluminum to fit in the groove on the back of the trim so i can run tape the entire length. I am going to try to do a test run on a piece this weekend before i do the whole truck.
05-07-2015, 03:06 PM | #11 |
That will be an interesting test Chase. If you can, please take pic's and let us know how it goes.
05-07-2015, 04:04 PM | #12 |
Yes, please do!
05-07-2015, 04:06 PM | #13 |
6>8 Plugless........
i'm interested to see your outcome as I had the same idea to put trim on my 76. I don't want to drill holes in the new sheet metal if I don't have to.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-11-2015, 11:35 PM | #14 |
How did it work?
05-12-2015, 10:31 AM | #15 |
Didn't make it to my shop this weekend... Luckily I remembered in time that it was mothers day I have a wedding out of town this coming weekend but hopefully I can come up with some time during the week.
I will post results hopefully sooner than later |
05-24-2015, 09:27 AM | #16 |
Any luck?
06-13-2015, 05:00 PM | #17 |
We are using only double sided tape and a few extra screws like what came with the kit. Seems to be working great and looks just as good without all the headache.
07-02-2015, 01:17 AM | #18 |
07-02-2015, 11:50 AM | #19 |
Looks Great! I haven't been able to get back on my project, but I think I am going to do it the same way.
07-02-2015, 12:04 PM | #20 |
07-05-2015, 07:34 PM | #21 |
if you use double side tape for anything use the primer/adhesion promoter on all your surfaces
it really improves the grip and life span on the tape most any body kit is held on with 3m grey double sided tape, they all come with adhesion promoter we ship the packets with any tape on product
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-06-2015, 08:26 PM | #22 |
I bought a complete side moulding kit for my 72 and was surprised to see that it came with double sided tape. I wish I had opened the box before drilling my doors. I haven't installed itthough, so I hope the tape holds up
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
12-04-2018, 12:00 AM | #23 |
12-04-2018, 12:23 AM | #24 |
Yes still holding good.
12-04-2018, 10:18 AM | #25 |
Thanks for the reply. I'll tape mine with confidence!
