01-09-2020, 08:44 PM | #1 |
brake lines which ones
doing a complete brake system. should i do stainless or steel ... I do like stainless but sounds like a people have issues with the flares leaking....looking for some input on which way to go
01-10-2020, 11:02 AM | #2 |
Re: brake lines which ones
We use hi-nickel steel. If you use stainless, it should be annealed for flaring.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
01-10-2020, 04:12 PM | #3 |
can you get the hi nickle straight? all the people i see using it looks slightly wavy
01-10-2020, 05:00 PM | #4 | |
I have also heard good results about using the hi-nickle steel Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-10-2020, 05:08 PM | #5 | |
01-10-2020, 06:31 PM | #6 |
I used ni-copp? tubing from front to rear on my 68 C10. It flares like butter. I bought it in bulk from Oreilly's. I do have a good flaring tool and have used it with good success on stainless but as said above I had to do some rework because I had some leaks.
Also if you do decide on stainless there are little concave washers made out of copper that can be put between the flare and the fitting to help seal the line to the fitting. Sorry I don't have a link. The thing I've found on flaring lines is the line prep before flaring. After cutting deburr the inside of the line. I use a small center drill. The a slight chamfer on the outside the line. Some lube on the flaring tool as you make the flare helps. |
01-24-2020, 04:31 AM | #7 |
Collector of Projects
I bought a roll on NiCopp off amazon.com and a flare tool. I will be doing custom brake lines as well as fuel lines for the LSx swap.... I also picked up some notchead fasteners to mount the lines.
http://www.amazon.com/Brake-Line-Uni.../dp/B07BMZ5FV2 https://www.notchead.com/store/p39/N...ne_Clamps.html |
01-24-2020, 02:18 PM | #8 | |
01-24-2020, 03:45 PM | #9 |
I opted for the Made in USA NiCopp brake line and am extremely happy with the bending/flaring characteristics. I am leary of some the made in China NiCopp lines. $35.09 and free shipping.
Amazon S.U.R&R
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
