12-15-2008, 07:17 PM | #1 |
Active Member
Questions about lifting my 1972 short box?
I purchased a 1972 short box not to long ago and was planning on putting a 3 inch suspension lift kit in. Does anyone have a preference for a kit? What will I all need to know about putting a lift kit in? The frame is rusted out over the rear wheel on the drivers side so over christmas break I will have to disasemble the truck down to the frame and I thought it would be a good time to do the lift.
_________________________________ 1972 Chevy SWB 4x4 350 4speed |
12-15-2008, 07:34 PM | #2 |
Re: Questions about lifting my 1972 short box?
Lots of guys use the Rough Country ez ride kits...
http://www.roughcountry.com/chevy_69-72_4.html or tuff country EZ ride http://www.tuffcountry.com/suspensio...lift-kits.html don't think anyone has 3" suspension, maybe 2 or 4"
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
12-15-2008, 08:30 PM | #3 |
i would do Skyjacker springs and Bilstein shocks. It will ride like a Cady.
12-15-2008, 10:34 PM | #4 |
20' Daredevil (Ret)
Very happy with my 2.5" Skyjacker Softride front springs. They came with rear blocks but I never used them (I have rear add-a-leafs). Pretty sure they make 4-spring kits which should work great on a SWB.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
12-15-2008, 11:18 PM | #5 |
I like Tuff Country 4" and good Ranchos.
12-15-2008, 11:51 PM | #6 |
If you go with a 4" lift, get a raised steering arm to correct your steering.
I've been pleased with Tuff Country EZ Ride springs - had a set of 4" of them on my 69 K20 initially.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
12-16-2008, 01:45 AM | #7 |
Tuff Country and Bilsteins - nice.
12-16-2008, 02:49 AM | #8 |
Active Member
Tuff Country 4" EZ Leaf Springs $234 x2 $468 JC Whitney
Rear Blisten F4-BE5-6248-H5 $73.28x2 $150 shock wharehouse Front Blisten F4-BE5-6252-H5 $73.28x2 $150 shock wharehouse $768 is that what I am looking for? What else would I need? Thanks
12-16-2008, 02:56 AM | #9 |
Are the front spings the same price as the rears? Or are you going to use the blocks? You will need a raised steering arm.......about 50 bucks.
12-16-2008, 03:02 AM | #10 |
Active Member
http://www.jcwhitney.com/TUFF-COUNTR...8403_10614.jcw
Each spring is tapered, snub rolled and preset. Order the heavy-duty springs for tougher uses — will accommodate a winch and is much better for heavy towing. Teflon inserts, used on both types, help with ride characteristics and to reduce squeaking. Note: Sold individually but you must purchase 2 for both driver and passenger side installation. I guess when I think of a lift kit I think leaf spring would beat blocks.
12-16-2008, 08:27 AM | #11 |
For many years you couldn't find springs for the rear. You were pretty much left with using blocks or having spring rearched at some spring shop. I ran 4 inch blocks in the rear for years and never had a problem. Never consider blocks for the front. They will spit out when turning.
12-16-2008, 11:23 AM | #12 |
you might need new U-bolts pending the length and condition of yours
are your brake lines long enough as well?
12-16-2008, 05:04 PM | #13 |
Active Member
Is there a better place to buy Tuff country springs with Blisten Shocks? Thanks
12-16-2008, 05:16 PM | #14 |
you could check a few 4x4 magazines, most times in there ads they have some sorta deal going on, do yall think a higher priced shock improves ride quality? or does the spring determine the ride?
im not happy at all with the ride of my tuff country 4 inch, with whatever brand shock that came in the deal. but i belive mudder suggested that it would(break) in as driven and honestly i didnt think that was possible, but after driving it awhile either im getting used to it or mudder was right, cause it does seem alil better.
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 Last edited by va_tlc; 12-16-2008 at 05:19 PM. Reason: added |
12-16-2008, 05:26 PM | #15 |
Active Member
Do you think a Skyjacker or a Rouch Country would be a better ride than the Tuff Country?
12-16-2008, 05:36 PM | #16 |
Not sure about the front springs but I would do a shackle flip in the rear. That way the pinion angle is better and you don't have the extra torque applied to the rear driveline from the blocks. DIY makes a shackle reversal bracket for less than 100.00 a pair.
12-16-2008, 05:58 PM | #17 |
It's a combination of the two, but yes I think some higher quality shocks than the ones that came with the kit would make a noticeable improvement. I really like the Rancho RSX9000's I have on my 69 K20 - you can dial them in to your liking. Always hear good things about Bilsteins of course.
12-18-2008, 09:07 PM | #18 |
thanks yj, that does make sense the ones on the black truck are shot, so when i replace em i will get a better shock than i usally buy, if i didnt re place the steering arm on a 4 inch kit, what will this cause? bad steering? wheel wobble? thanks
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
12-18-2008, 09:25 PM | #19 |
you'll get "Bump Steer" if you don't replace the steering and/or pitman arm with big lifts.. Due to the extreme angle of the drag link your truck will steer one way or the other when the suspension flexes, or you hit a BUMP...hence BUMP STEER...
12-20-2008, 04:08 PM | #20 |
Active Member
Does this mean you get the 4 leaf springs for $560? Thanks for the help.
1969-1972 Pickup, Blazer, & Suburban - 1/2 & 3/4 Ton - EZ-Ride Lift Kits w/ 52" Rear Leaf Springs http://www.truckaddons.com/Catalog/s...y-chevy_04.htm
02-18-2009, 01:38 AM | #21 |
Active Member
I have bilstein shocks and raised steering arm but my lift kit I ordered through truck addons was refunded. Where do I learn more about flipping the rear shackel. I am kind of looking at Rough Country with rear blocks they seem much cheaper than an other lift kit but I don't need the shocks that come with the kit.
02-18-2009, 08:37 AM | #22 |
You should be able to buy the blocks by themselves if that is all you want. You need to call some of the places you are looking. I ran 4" blocks in the rear for many years and never had any problems with them.
02-18-2009, 09:11 AM | #23 |
WTB this ad
Off road design makes the rear shackle flip. My brother runs one on his blazer.
http://offroaddesign.com/ |
02-19-2009, 09:39 AM | #24 |
Why don`t they list a 69-72 2 1/2" shackle flip?
02-19-2009, 02:00 PM | #25 |
TexasBowhunter
Use a set of front spring hangers.
Build in progress for son's first truck. |
