Old 05-13-2004, 09:23 PM   #1
53burb
53burb's Avatar
Dual A/C
I am considering buying a '69 Chevy Burb. It has SBC. I would like to run front/rear air. Vintage Air has the complete unit minus the rear air for about $1100. Will a rear air unit out of a '73-91 Burb bolt in place? Vintage Air says their unit is adaptable to this. Any pitfalls, suggestions, or shortcuts does anybody know about this? Has anybody done this? Thanks.
53burb is offline   Reply With Quote
Old 05-14-2004, 03:42 AM   #2
68 Suburban
68 Suburban's Avatar
I would like to know how the connect the lines for the 2 units?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-14-2004, 08:05 AM   #3
gregfull
gregfull's Avatar
Hey Guys,
I'm building a suburban with the same setup. Steve Black, with Steve's Classic Auto Air is the man to talk to. He is a Vintage Air Dealer and has done several dual air setups. He is very knowledgeable and very helpful. Another board member has used him recently and posted how helpful he was on the board. He is located in Houston, but he will ship anywhere. His number is 713-688-3884. Good Luck.
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 05-14-2004, 09:56 AM   #4
53burb
53burb's Avatar
thanks
Thank You for the Heads Up. I will give him a call...
Old 05-14-2004, 10:25 AM   #5
smokekiki
Mike
smokekiki's Avatar
On my 72 with factory daul a/c,there is just a T fitting in the 2 lines.1 on the high side and 1 on the low.The lines run along the frame,then crossover above the rear of the trans.They then enter the floor and run along the inside of the q-panel,and up the inside of the rear post and into the rear overhead unit.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
