Old 05-16-2004, 09:05 PM   #1
emmett
emmett's Avatar
weight
Hi guys, Does anyone have any idea what a burb tub with only the third door weighs interior is striped tub is pretty solid let me know.
Thanks EMMETT
Kaukauna WI Airplaines don't land here they are sucked down
emmett is offline   Reply With Quote
Old 05-19-2004, 12:11 AM   #2
emmett
emmett's Avatar
Tub
Ok did any one lift a striped burb cab if by man power how many men? If with a cherry picker how did it work, I am just trying to figure out if my trailer will hall it about 400 miles. Or has anyone halled one and on what kind of trailer? I have a older double wide snowmobile trailer the frame has ben beefed up the axel is rear axel from a dodge carrivan with 14" wheels it can handel a pretty good load, I would guess a C-20 cab at about 300lbs stripped, I cut mine into three pieces and loaded it on the trailer by my self I am guessing a burb would be about 2.5 to 3 times more. Any input would realy be appreciated.
Thanks In Advance EMMETT
Old 05-19-2004, 06:30 AM   #3
TexSparks
I used an engine hoist attached in the rear door opening to lift rear and an "A" frame with chain hoist to lift front. Mine had all doors and glass, I figured 1000-1500 lbs.
'72 4x4 Blazer (in the works)
TexSparks is offline   Reply With Quote
Old 05-20-2004, 03:01 AM   #4
emmett
emmett's Avatar
Thanks Texsparks Thats pretty close to what I was guessing my trailer will handle that nicely.
Thanks Again EMMETT
