Old 05-31-2004, 01:28 PM   #1
Martin64
Martin64's Avatar
Glove box installation help
I just bought a new glovebox insert and don't want to screw it up.....any hot tips?
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 05-31-2004, 01:44 PM   #2
smitty62
smitty62's Avatar
Don't tug on Superman's cape!
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 05-31-2004, 01:56 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I just take's a little finess don't be in a hurry with it...Make's it real easy if you remove part of the heater box on the firewall inside the cab..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-31-2004, 02:06 PM   #4
19mike69
when i did mine (ac) i had to reroute a few of the defrost hoses to get mine in.But like they say,go easy and slow and it will go.....it looks like it wont,but it will :p
he who dies with the most toys wins...
19mike69 is offline   Reply With Quote
Old 05-31-2004, 07:11 PM   #5
Martin64
Martin64's Avatar
That's what I was thinking. Kinda angle it in from the top and get it in place and then work the bottom into place... or just work the whole thing in a little at a time?
Thanks guys
Martin Gibson
USAF Retired
1964(-ish) C10
Old 05-31-2004, 10:19 PM   #6
A few 72's
A few 72's's Avatar
May want to put some of the sealant/caulk or matal duct tape on the outside seams before you install it. Will not show put will keep the water out if you ever get a leak around the windshield or antenna hole. Did not do mine and about a week later got some water in mine due to the way the seam was made on the new one.
A few 72's is offline   Reply With Quote
Old 06-01-2004, 12:00 AM   #7
Martin64
Martin64's Avatar
It was actually pretty easy since it's a non-a/c model. After I got the glove box door off it just slipped right in. I did have to trim around the latch a little bit to get it to close but a utility knife made short work of that.
Martin Gibson
USAF Retired
1964(-ish) C10
