Old 06-17-2004, 09:23 PM   #1
mastercraftkpk
crankshaft casting number help
Does anyone have a good source for looking up SBC crank casting numbers?
I have a 350 crank w/#3832442.
TIA
mastercraftkpk is offline   Reply With Quote
Old 06-17-2004, 09:33 PM   #2
CanadianFolk
CanadianFolk's Avatar
http://www.mortec.com/notepg1.htm
CanadianFolk is offline   Reply With Quote
Old 06-17-2004, 09:45 PM   #3
Sweet72
Sweet72's Avatar
Can't seem to find your crank casting no on either the mortec or nastyz28 sites. Two other casting numbers with 383XXXX are 265's and 283 50's and 60's vintage.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 06-18-2004, 01:57 AM   #4
CanadianFolk
Crank-3832442.......stroke 4.000x3.484
Conecting rod forge no/s 3923282 or 3946841
350-5.7 high preformance..thatll bring smile to ya..
67-95
....not that lm a know it all but l can copy and paste realy good ..cheers. :O)
Old 06-18-2004, 01:59 AM   #5
CanadianFolk
do google seach gm 3832442
Old 06-18-2004, 03:47 AM   #6
jimfulco
Casting numbers are sometimes not clear. The -442 crank is 3932442.
jimfulco is offline   Reply With Quote
Old 06-18-2004, 03:35 PM   #7
mastercraftkpk
Thank you ?Gentlemen?. It seems to be the orig/stock crank for my engine('71 LT1).
The cylinders are still stock size w/ very little taper and not out of round, but I found a deep score on the last cylinder I honed this afternoon. Looks like I will need to bore @30. To bad
Thanks again.
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
