Old 07-25-2004, 04:26 PM   #1
method2mymadnes
method2mymadnes's Avatar
Steering
I have an 87 cavalier, at idle the power steering does not work. with the engine revvvvved up it works. Is the problem the pump or the rack? I think if the pump was bad it would not work at all, or it would be whining.
method2mymadnes is offline   Reply With Quote
Old 07-25-2004, 09:01 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Sounds like pump. As they get worn, you have to spin them faster (revving it up) to make enough pressure to work.
