Old 07-31-2004, 01:33 PM   #1
78SilveradoSWB
78SilveradoSWB's Avatar
Question Drop Shackle or Lowering Block? Why?
Which is the more preferred method to drop rear of 73-87 C-10 in conjunction with flip kit to attain a 6 " drop, a 1 inch lowering block or use of a drop shackle? Reason?
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 07-31-2004, 10:05 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Shackle. Blocks are bad IMO.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 07-31-2004, 11:15 PM   #3
BaggedC10
Under construction!
BaggedC10's Avatar
I agree w/ Mike. Shackles are the way to go.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 08-01-2004, 02:42 AM   #4
78SilveradoSWB
Thanks for the input and advice.
Mitch
454 BB, TH400
Old 08-02-2004, 11:57 AM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Getting in this late, but I agree. Blocks are not a good idea in my opinion.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-02-2004, 05:50 PM   #6
Grim Reaper
A 1 inch block would not be bad even a 2 but blocks do tend to make spring wrap worse. The problem with the shackles is they may throw off your pinion angle but even that's mute point since your doing a spring under. Your going to have to do new spring purch anyway. If your going big HP do the shackle for sure but otherwise...what ever is cheape just make sure the block is solid STEEL. www.offroaddesign.com sells a 1 inch block that also lest you move the axle forward and back if your having problems with the wheel not centered in the wheel well.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
