Old 08-08-2004, 09:29 PM   #1
GarageGhoul
Low and low budget
I currently have a 2/4 inch drop kit, but I have only installed the back springs and want it lowwer. I want to go as low as possible without clearence problems. would 3 inch blocks work? what are the draw backs? another question are flip kits only for leafs? any and all info/advice please.
(keep in mind, low budget)
GarageGhoul is offline   Reply With Quote
Old 08-08-2004, 09:41 PM   #2
ed455
Captain Ed
Wait until you drop the front. I thought the same thing until I dropped the front then the back looked just right *for me*.
ed455 is offline   Reply With Quote
Old 08-09-2004, 01:14 AM   #3
flatblackclassic
What kind of vehicle is this? I'm assuming you have leave springs since you are asking about blocks. I honestly wouldn't go with a lowering block as they have a tendency to cause axle wrap with can cause LOTS of problems down the road. A Shackle or Hanger would be your best bet to get the truck closer to the ground.
flatblackclassic is offline   Reply With Quote
Old 08-09-2004, 01:30 AM   #4
GarageGhoul
sorry forgot to say its a 63 c-10(coils).
63 c-10 shortbed fleetside
Old 08-09-2004, 01:34 AM   #5
flatblackclassic
YOu could actually do some BAGS fairly cheap. It will give you a much better ride. Simply replace the coil spring with a bag. You will need a new panhard bar for about 150 bux. There's really no need for a compressor unless you want to adjust the ride height all the time. You can do that setup for under 500 bux if you shop right.
Old 08-09-2004, 01:41 AM   #6
GarageGhoul
can I do it for the front also or will I run into problems. I know the back is easy but I dont know much about doing the front with bags
Old 08-09-2004, 10:57 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Put a block in the rear. Being a coil truck, there is no issue with spring wrap, just watch the scrub line.
