Old 08-13-2004, 11:33 AM   #1
cochino12
It followed me home?
cochino12's Avatar
"clunk" after T-case drop
So I lowered my t-case to get rid of some vibration and now I have a clunk when i park, hit small bumps? Any ideas? could the angle of the driveshaft messed up the ujoints?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-13-2004, 12:26 PM   #2
Mudder
Mudder's Avatar
How much did you lower it? The universal may be binding.
Mudder is offline   Reply With Quote
Old 08-13-2004, 12:35 PM   #3
cochino12
cochino12's Avatar
Only about 1", I used the stock spacers.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 08-13-2004, 12:37 PM   #4
Mudder
Mudder's Avatar
Thats all I ever lowered any of mine and never had any problems.
Old 08-13-2004, 12:39 PM   #5
Mudder
Mudder's Avatar
Maybe one of the drive shafts is hitting (needs to be shortened).
Old 08-13-2004, 12:43 PM   #6
Destructo
Mine has a little knock when I come to a stop, I think its the chain in mine, but mine is not lowered and my truck sits stock now.
I was running mine lowered the same as yours for awhile when I had the 4" lift on it and didn't really have any problems.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 08-16-2004, 11:45 AM   #7
CHEVYJEFF
CHEVYJEFF's Avatar
check tranny mount, also check front shaft, may need to grind the factory stop points on the cv end.
http://members.cardomain.com/chevyjeff
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
97 REGAL LSR 2100 (BOAT)
CHEVYJEFF is offline   Reply With Quote
Old 08-17-2004, 12:47 AM   #8
soleeagle
soleeagle's Avatar
When I lowered mine I had to grind the stops on the front driveshaft closest to the transfer so it wouldnt bind. You might want to check it out.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
