Old 08-28-2004, 10:49 PM   #1
9teen69
9teen69's Avatar
Lift installed
2 pitchers of sweet tea later... the lift is pretty much done. Just need to do brakes, u-joints, sway bar , etc, etc and save 1500 bucks for rims and tires.
It all came apart pretty easy - WD40 and liquid wrench did the trick. Wacking the steering arm up and done was also a nice idea - it also helps having a buddy with arms twice as big as mine.
Removing the TC bushings and replacing with the greasable ones was a slow down but will be worth it in the long run.
How do I get this nut off - do I need a special tool?
Hope I can get it out of the garage.
Thanks for all the help!
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 08-28-2004, 11:44 PM   #2
Mudder
Mudder's Avatar
Takes a special socket... its big and has 4 little l_l on it... that fit into the nut. Have no idea what its called.
Mudder is offline   Reply With Quote
Old 08-29-2004, 12:13 AM   #3
super72
super72's Avatar
It's a hub removal socket, you can pick one up at the parts store for less than 10 bucks
super72 is offline   Reply With Quote
Old 08-29-2004, 09:04 AM   #4
orangeuavol
GO VOLS!
orangeuavol's Avatar
The hub nut on my Dana 44 front end amazingly was exactly the same size as the hub removal socket I bought for a Honda CRX several years ago.
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 08-29-2004, 04:04 PM   #5
lovemychevy
how much lift is that and if you ever come back to texass would like to see in action
lovemychevy is offline   Reply With Quote
Old 08-30-2004, 10:36 AM   #6
9teen69
9teen69's Avatar
It's a 6" Tough Country. I can't wait to get some tires under it and go beat on it.
It's not "if" it's "when" I just visited my grandparents in Plano and it made me miss home that much more. Didn't realize how rude I had gotten living in NM. It's amazing how people would wave as I drove down the street and even moved over when getting on the HWY. They don't teach the "merge" word here.
Old 08-30-2004, 10:44 AM   #7
Mudder
Mudder's Avatar
I see one thing you should do different next time.......... Get rid of the cider blocks under the jackstands....We don't wanna loose ya here. 2x12's work good for that.
Old 08-30-2004, 03:46 PM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
"Hope I can get it out of the garage." Geez, if your garage door is the same height as mine you won't be able to - my K20 when it had just 4" of lift wouldn't go in my garage.
Definitely a good idea to stay away from cinder blocks, I did that once before and after seeing how easy they shatter, I won't do that again - ever!
Will look forward to seeing finished pics.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-30-2004, 05:51 PM   #9
9teen69
9teen69's Avatar
I'll try airing down the tires on my 69 or I'll have to use the jacks to roll it out.
I'll definetly replace the cinders with some wood.
Old 09-12-2004, 05:37 PM   #10
Jason71k10
ready for reassembly
Jason71k10's Avatar
ditto what mudder and yukon said....especially on there side, there's no strength to them that way. I would definitely get some wooden blocks under there!
stock 71 4x4
2003 Jeep Liberty, rocky mountain edition
I'm obsessed, and wouldn't have it any other way!
Jason71k10 is offline   Reply With Quote
