09-13-2004, 09:02 PM | #1 |
383 with 10.3:1 CR too high for pump gas?
I've been looking at the 383 stroker flat top rotating assy. from Scoggin Dickey Parts Center www.sdpc2000.com , and want to use the GM Performance Parts Vortec heads w/64cc chamber due to the cost/performance, however this combo supposedly will make a 10.3CR! Will I have to mill the pistons down, or what are my options to make this thing run on pump gas? Thanks. Sam
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
09-13-2004, 09:36 PM | #2 |
driving is in my blood
Run a cam with at least 220* duration and 110* LSA and tune the ignition and you'll be fine on 91, I did. 385 w/ vortecs, 10.2:1 compression, and 214* duration comp cam with a stock HEI
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
09-13-2004, 11:06 PM | #3 |
"pumpgas" ??? we have it available in octanes up to 106 don't see why it wouldn't run on pumpgas
09-14-2004, 01:06 AM | #4 |
in CA the highest is 91 octane
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
09-14-2004, 02:17 AM | #5 |
10.3:1 is marginal at best with aluminum heads in my opinion and to high for iron heads. the cost in milling pistons down is about equal to dished pistons when you figure in the value you pay in the kit. i honestly think you would be taking a step backwards and spending more than you had to, which is a major piss off when your on a budget bacause that usually ends up being extra money your could have spent upgrading to roller rockers or something like that. theres load of these kits on the internet. summit, jegs,PAW,powerhouse,strokerkits.com,EBAY and many others. I would try and find the kit that gives you more like 9:1 - 9.5:1 at the highest. even if you have to spend a little more. thats my .2 cents
--Scott |
09-14-2004, 02:20 AM | #6 |
NOT REALLY BANNED!
My 11:1 327 ran fine on 94 octane.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
09-14-2004, 04:05 AM | #7 |
Run a tight quench and a cam with a fair bit of overlap and you should be able to do it
I have flat tops in mine with 64 cc iron heads as well and it has never knocked once on 91 octane |
09-14-2004, 02:29 PM | #8 | |
a.k.a. the reason that a really hot cam in a 327 will be choppy, while the same cam in a 406 with identical heads compression etc. will be more rumbly, less radical sounding, and more streetable. but on that same token requires a more stable fuel(higher octane) to not have pre-ignition and detonation problems due to natrualy higher low end cylinder preasures. --Scott |
09-14-2004, 06:29 PM | #9 |
I'm planning on running 10.9 on 91 octane. W/aluminum heads, 6.0 rods, 220° w/112° LSA roller and EFI. And I don't plan on keeping a barrel of toluene in the garage.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
09-14-2004, 07:19 PM | #10 |
John Deere Tech
I'll ask the question that hasn't been asked yet. What are you planning to do with the truck? If you're going to be using it hard and/or towing, or will be running in high ambient temps, it's going to be more prone to detonation, regardless of cam specs, cylinder head type, etc. Hot and/or heavily loaded engines are more likely to experience detonation at a given octane number and compression ratio, period. If you're going to idle around town or blast down the highway with no load, you might be okay, and you could always pull out a couple of degrees of timing in order to dial in a safety factor. Were it my valuable time and money going into the engine, I'd rather be safe than sorry, and would lean toward a little less compression instead of just "getting by".
'72 C20 350/TH350/Dana 60 coils Factory Black/Light Green Interior - Undergoing restification and A/C installation. Daily driver. '72 C20 350/TH350/Dana 60 leafs Light Blue/White Cab Factory A/C - Currently building a 383 to GMPP HT383 specs. |
09-14-2004, 11:42 PM | #11 | |
very valid thinking...something to think about...the actual HP gain from 9.2-1 to 10.2-1 is about 10 HP(using a cam suited for 9.2-1) where the bigger gains come is when you use a bigger cam, heads, exhaust to take advantage of the higher compression. In a non max effort sbc..play it safe..go with a smalle CR and optimise the timing.
09-15-2004, 12:18 AM | #12 |
I have an engine similar to yours except it is a 355. I am running flat tops with vortec heads, .025 deck height and .039 gasket (quench about .064). Also, I am running a relatively mild cam (ZZ4) with 208 intake duration.
I was scared to death that I would have gas problems based on what a lot of guys told me. But I run this thing all day long on 89 octane and have run 87 octane and didn't notice and detonation. I did smooth out any sharp corners or edges in the combustion chamber of the heads that might have caused a hot spot. I don't know if it helped but it sure didn't hurt.
71 Factory SWB 4x4 Project 383/350/205 69 LWB 2wd CST Daily Driver ZZ4/700r4/3.73 72 SWB Future Hot Rod |
09-15-2004, 12:46 AM | #13 |
Just my 2 cents, and please correct me if I am wrong.
I was always told that detonation occurs from heat, and a higher octane fuel, being harder to burn, means less chance of detonation. That being the reason gas stations want you to buy premium, less spark knock they call it. A higher compression ratio, (under 11:1) with a high octane fuel (91+) would be the equivalant of 87 octane with 9:1 comp. (assuming correct A/F ratios, timing is right, etc, etc.) I have run 11.5:1 on 94, and although the engine ran questionable at best, it was streetable. 106 ran great but at 3.79 a gal. run time was minimal. |
09-15-2004, 12:55 PM | #14 |
i have "10.5:1" keith black pistons and after the formula was completed on my motor just recently, its actuall 9.5:1 compression. just me 2 cents...
09-15-2004, 05:33 PM | #15 |
i had kb 10.5 to 1 pistons in my old 327 with ported iron heads and a pretty big solid cam and it ran just fine on 91 pump gas. the cam duration helped alot.
Anthony |
09-15-2004, 05:42 PM | #16 |
383 10.3 too much for pump gas?
Thanks very much fellas for all the super replies. I knew you woudn't let me down. In answer to CJM72CHEVY's question: What are you planning to do with the truck? It will be an occasional street driven fun truck, taken to shows, and at times I may require that it be used as it was intended. Definitely not a trailer queen. I called Scoggin Dickey about substituting -12cc dish pistons and was informed that they would rather not break up their kits, and that would be a special order $$$. I see that Jegs sells a set of Speed Pro hypereutectics for $223 and they have the -12cc dished that I'd need to get my compression into the low to mid 9 range and additional tweeking could be done by varying the head gasket thickness. Now I wonder if I could unload the -7cc Speed Pro flat tops that come with the kit on ebay. Oh, cdowns, I guess the airport has a pump that I might be able to get some of that high-test, and maybe I'll consider running a 12.5CR with water injection .
09-15-2004, 09:47 PM | #17 |
Before playing around with head gasket thickness to adjust compression read this:
http://www.speedomotive.com/Building%20Tips.htm
09-15-2004, 10:24 PM | #18 |
"If you have a 10:1 engine with a proper .040" assembled quench and then add an extra .040" gasket to give 9.5:1 and .080" quench you will usually experience more ping at the new 9.5:1 ratio than you had at 10:1."
This must be what you're referring to neonlarry. Thanks for the heads up. (pun intended)
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. Last edited by Sweet72; 09-15-2004 at 10:30 PM. |
