Old 09-14-2004, 10:12 PM   #1
Bhull2
35s with 2" lift?
Is it possible to run 35s with a 2" lift? I am in the process of rebuilding my 72 k20, and have run across a great deal on 35 x 12.5 tire wheel combo. Just wondering if it will work, how much it will rub on turns (I will be able to turn, right? ) ect..... Has anybody tried this combo? Any info would be greatly aprreciated...
Bhull2 is offline   Reply With Quote
Old 09-14-2004, 10:18 PM   #2
ProjectK-10
ProjectK-10's Avatar
I dont know if I would try it with only a 2" lift. I have a 4" with 35's and that is ok, but they come really close to the front of my fenders ( luckly I havent scrapped them ) I would go with 33's max with that lift.
'72 K-10 Longbed, 4" Lift, Rancho RS9000 Shocks, Trailmaster Springs(soon to be replaced), 35" Procomp Tires, Freshly Rebuilt 350, TH350, NP205, and More To Come
ProjectK-10 is offline   Reply With Quote
Old 09-15-2004, 06:14 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I'm running 35" BFGs w/ an advertised 2" lift, they are the 2" heavy duty springs from Tuff country. I also have about 1/4" of lift from ORD shackles. I netted about 3.5". They will rub every now and then. My 33" TSLs did not rub. How wide are your rims?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 09-15-2004, 01:42 PM   #4
Dean
Dean's Avatar
I'm running 35" BFG with 4" lifts on my K20. I wouldn't even want to do any extreme offroading with that combo. I'd stick with the 33" with the 2" lift.
Dean is offline   Reply With Quote
Old 09-15-2004, 06:44 PM   #5
smokkey1
Land Beast
well break out the swazall and they'll fit.
90' GMC 1 Ton Suburban
smokkey1 is offline   Reply With Quote
Old 09-15-2004, 08:12 PM   #6
elk hunter
depends on wheel off set. my buddy has a 74 blazer with no lift and runs 35s on 8" wheels with no rubbing problems.
yeah, but how's it wheel?
elk hunter is offline   Reply With Quote
Old 09-16-2004, 09:25 AM   #7
Bhull2
Thanks for all of the input... I guess I will not get them I do not have the truck together yet, and would hate not to be able to use them, or worse yet, tear something up with them if I articulate the suspension at all. Better to be safer with the 33s....
Old 09-16-2004, 05:11 PM   #8
wildwood
wildwood's Avatar
I put 2.5 susp lift and 2" body. 35s never rubbed with this combo. Here's a pic of that setup.
You can't get out if ya don't get in
wildwood is offline   Reply With Quote
