Old 03-21-2002, 12:45 PM   #1
prenfroe
Question Negative Battery Cable
Does anyone have a picture of the negative battery cable and how it connects in your V-8? I have been told that the cable from my inline 6 might not do with my new V-8 motor. I was told that it needs to be connected to the block and the frame in the V-8. Thanks for your help.
prenfroe is offline   Reply With Quote
Old 03-21-2002, 12:54 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Post
On my mighty 307 (mighty tired that is) the negative cable goes from the battery directly to the front of the passenger side of the engine block.
1969 C20 4x4 with roughly 6" lift and 35's
residing near Rose Hill, Kansas
Yukon Jack's Web Pages
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-21-2002, 12:57 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
can connect anywhere you want it to, it really doesnt matter, on the long water pump engines it connects to upper alternator bracket in most cases, and see them connected on the older engines down near the fuel pump alot,
but not in the 84 maro, and other newer vehicles sometimes, it connects to the front of pass side head, i moves it to driver side when I replaced it because it was longer, i didnt want to shorten it hehe,
you can bolt it to wherever you want really, make surew where you mounbt it is dirt rust and grease free though ! wd40 is good to spray wherever to prevent corrosion, same for all electrical plugs and connections etc etc
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies
-79 G20 pass van, 350/th350/10bolt,
paint is overrated
Randy- Lincoln, IL
randy@ccaonline.com
© RSS Enterprises 2000
[This message has been edited by Fast68Chevy (edited March 21, 2002).]
Fast68Chevy is offline   Reply With Quote
Old 03-21-2002, 12:58 PM   #4
COBALT
COBALT's Avatar
Post
On my parts truck the neg. cable goes right to a bolt on the passenger side of the engine block.
On my daily driver they put in a later model 350, so they replaced all the brackets for the accessories. Therefore, they ended up tying it to one of the accessory bolds that connect to the block (I think the alternator).
Basically, its the same connection.
'69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed!
'69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast).
Seattle, WA.
*See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
