Old 12-05-2004, 02:01 AM   #1
78ChevySilverado
I love my Chevys
78ChevySilverado's Avatar
"Z" ing the frame
I'm thinking about doing this to my 78 CHevy and I need some help. If you can provide detailed instructions, pictures, problems that I will encounter etc. it would be greatly appreciated. Thanks.
78ChevySilverado is offline   Reply With Quote
Old 12-06-2004, 08:11 PM   #2
78ChevySilverado
I love my Chevys
ttt
Old 12-06-2004, 09:27 PM   #3
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
I ran across this board members page. I will be z'ing a 2WD Blazer frame SOON!
http://www.loweredd.com/Frame_Z.html
FuelCellGuy is offline   Reply With Quote
Old 12-06-2004, 09:34 PM   #4
BK
BK Built
BK's Avatar
yeah, that site has some good pics. I will also be Z-ing my frame next week, on my 65 panel, and a friends 80 chevy stepside. Ill take lots of pics and let you know how it goes, just be aware steering u-joints are spendy.
BK is offline   Reply With Quote
Old 12-30-2004, 01:33 PM   #5
Col Clank
How goes the progress?
Col Clank is offline   Reply With Quote
Old 12-30-2004, 03:11 PM   #6
BK
BK Built
BK's Avatar
hopefully my metal is here today, and i should be attackin it today, wish me luck
Old 12-30-2004, 08:36 PM   #7
drasticwagon
drasticwagon's Avatar
Cant wait , I think ill be cutting my frame tomorrow on my day off...
drasticwagon is offline   Reply With Quote
Old 12-31-2004, 04:21 AM   #8
BK
BK Built
BK's Avatar
Well, i did it. its a 4" z, and im using 1/4 cause they had no 3/16 available until a week later, so i said why not. so ive got the rear sides all welded up, just need to cap it off. As you can see i boxed the inside, give me a little more strength. I will hopefully do the front in the next day or 2, depends on if i go snowboarding tomorrow. So to make everything easier, i did move the engine ahead 3", so i shouldnt have dist. clearance problems, and if you can see in the last pic, looking through the big hole in my firewall(which im almost done shaving) you can see my ECE auto tranny crossmember, simply flipped upside down, works perfectly. Also, you may notice in one pic my new firebird tilt steering column. Enjoy, ill get more pics soon.
Old 12-31-2004, 06:01 AM   #9
BaggedC10
Under construction!
BaggedC10's Avatar
Nice work, man! Keep us updated.....
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 12-31-2004, 12:19 PM   #10
drasticwagon
Awesome , i definantly cutting mine today....
Old 12-31-2004, 01:00 PM   #11
Shev
Head Peon
Shev's Avatar
How about starting a new thread for each and make at least make one of them a sticky so we don't have the same ?'s over and over...
Nice work by the way When it's all said and done give us an honest opinion on the difficulty of this mod, I want to do it but I'm scared...LOL...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 12-31-2004, 03:18 PM   #12
NO LONGER DISTURBED KONCEPTZ
NO LONGER DISTURBED KONCEPTZ's Avatar
Looks good man.
NO LONGER DISTURBED KONCEPTZ is offline   Reply With Quote
Old 01-02-2005, 10:39 PM   #13
drasticwagon
Well i started mine today , here are some pics as well as some pics of my son with his bike we are building.
Old 01-03-2005, 09:40 PM   #14
Sweet man
Old 01-07-2005, 10:57 PM   #15
BK
BK Built
BK's Avatar
Well, i hope you all enjoy the pics, i know i sure do!!! I got the 3" spindles on, got 205/75/15 tires on it, have the engine and tranny in it, recessed the bumper 1/2", flipped my ECE tranny crossmember over and dropped the center 1&1/4" to match the 4" Z and so have room for exhaust, got the TA x-member in, got it all ground and painted, cut a good sized hole in the core support for my steering box, and so its all good. Got my box tubing for the rear so i should get that going. Enjoy!
Old 01-07-2005, 11:12 PM   #16
drasticwagon
Nice job homie!
Old 01-08-2005, 11:13 AM   #17
SCOTI
SCOTI's Avatar
How about some pics @ 80-90psi of air. What's the crossmember height from the ground then?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-08-2005, 04:47 PM   #18
Looks good man
Old 01-10-2005, 09:50 PM   #19
81chevystep
ShadeTree Kustomz
81chevystep's Avatar
what are u guys doing for the stering hook up, i z-ed mine 3 inches and ny steering shaft hits my upper control arm when layed out. i was just going to get a steering joint or two to get it to work. just wondering what you guys were doing
-chris-
1981 c/10, 383 fully built bagged, custom interior. built entirely by me
81chevystep is offline   Reply With Quote
Old 01-11-2005, 11:27 AM   #20
grnddwn
belly dragger
grnddwn's Avatar
I just did one with a big notch in the upper control arm seems to work fine but we re- enforced the hell outta of it after.
grnddwn is offline   Reply With Quote
Old 01-11-2005, 03:49 PM   #21
BK
BK Built
BK's Avatar
I dont think we can notch our upper arms, cause we went 4". Im thinking just the 3 u-joints and a heim joint should do it, im not sure though, i still dont have my body back on... got the rear notch almost done(lays frame) just gotta get the exhaust done, then body is going back on.
Old 01-11-2005, 05:50 PM   #22
grnddwn
belly dragger
grnddwn's Avatar
Yeah we went 3 1/4 with the crossmember and it required a pretty big notch.
Old 01-11-2005, 10:28 PM   #23
81chevystep
ShadeTree Kustomz
i think i'm going to go with 2 u joints and a heim joint becuase the steering shaft crosses way to close to thebushing of the upper control arm thanks guys
-chris-
Old 01-12-2005, 12:10 AM   #24
bagged74
its just $$$$$
bagged74's Avatar
4" seems kind of drastic. How much pressure is it gonna take to get that thing up high enough to drive? Maybe im missing something, but it looks to me like you could have gotten away with 3" or so. anyway it should look awesome with the body back on.
bagged74 is offline   Reply With Quote
Old 01-18-2005, 02:09 AM   #25
pissonNOS
senior member
pissonNOS's Avatar
maybe im being stupid here but i dont understand the geometry about Z ing the frame how does it make the truck so much lower?
69 GMC bagged
pissonNOS is offline   Reply With Quote
