Old 03-28-2001, 01:35 PM   #1
Rusty67C10
Post Cahnging 6 lug to a five lug
Ok guys I have no idea how to do this, not what is the best way. Does anyone have any insight into this matter?
RUSTY
chevyc101967@yahoo.com
1967 Chevrolet C10
Wanting a BURB
Rusty67C10 is offline   Reply With Quote
Old 03-28-2001, 01:54 PM   #2
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Post
4x4 or 2wd? 1/2 ton or 3/4? Front disks or drums? The front is easy. Change to 5 lug disks from a 71 or 72. 73-? can also be used with some modifications and appropriate ball joints. The rear is easy too if you know which axles are interchangable. What year is your truck? Can anyone else help out on the rear?
70 Jimmy 454 2wd
56 GMC Big Window
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 03-28-2001, 01:56 PM   #3
Rusty67C10
Post
2wd, 1/2 Ton, Drum brakes
RUSTY
1967 Chevrolet C10
Wanting a BURB
Old 03-28-2001, 02:02 PM   #4
ImpalaSS
Post
get the complete front suspensien assembly from a 73+ truck (up tell about 80 when they went to metric) the 73-87 trucks have rubber control arm bushings which is better than the stock 67-72 ones... will need to drill two more holes in your frame for the crossmember to work but nothing bad.... and for the rearend get the complete rear end out of a 71-72 C10
www.xframeimpala.com
68 4x4 short fleetside deluxe cab 327 air
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
ImpalaSS is offline   Reply With Quote
Old 03-28-2001, 02:58 PM   #5
JJR
JJR's Avatar
Post
From your photo on another post, you have good six lug wheels. If you want to keep them you can do as ImpalaSS said but order 6-lug rotors and keep your rear end the way it is. Or you can get spindles off a 71/72 and change your ball joints and tie rod ends. By the way, which Athens do you live in? (GA, TN, TX, Etc.)
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 03-28-2001, 03:20 PM   #6
Low69CST
Post
If your going to change the rear to a 5 lug patter, i'd change housings. I hear people say that some axles are interchangalbe perfectly, but i've found that all the 5 lug axles are longer than 6 lug axles. The results is your drum doesn't line up with the shoes right plus, the outter axle bearing won't ride on the machined part of the axle.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, all stainless hard and flex lines, Dana 9 1/4" rear end 4.11's w/Detroit Locker, soon to have 18" rims
Looking for some parts to your truck or just want to see my truck? See it at www.geocities.com/low69cst/index.html
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 03-28-2001, 04:44 PM   #7
djracer
djracer's Avatar
Post
I have everything you need to make it 5 lug power disc. The stuff is used off a project truck. I'd take 200.00 for everthing shipped. You will need new pads, hoses and turn the rotors. But the rest should be fine. booster, mastercyl, spindles, rotors calipers
67 swb fleet Soon to haul a**
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-28-2001, 05:13 PM   #8
Shane
Shane's Avatar
Post
Welcome Aboard! Anytime you have a question, just post it here and someone will give you an answer! These are some of the most knowledgable folks you will ever run across conscerning these trucks.
I'm from Athens, AL, which Athens are ya from?
Keep On Truckin'
Shane
nduroracer@aol.com
[This message has been edited by Shane (edited 03-28-2001).]
Shane is offline   Reply With Quote
