Old 03-31-2001, 09:01 PM   #1
Bulldog
Post Disc brake swap
Ok I have a donor 81 chev 1/2 ton truck. to swap to a 69 I take everything off the front of the 80 and put on the 69? upperand lower a frames, drag links cross member and all. Right? Someone said something about drilling new holes for something? where? Thanks
Bulldog in Hamilton, Texas
69 GMC Stepside 350 Voetec SBC
Bulldog is offline   Reply With Quote
Old 03-31-2001, 09:59 PM   #2
woodmancfh
GMC RULES
woodmancfh's Avatar
Post
Bulldog, I did a disc brake swap on a 68 about a year ago.The parts truck was a 79. I left the stock A-arms and put 79 ball joints on them.(the studs are longer on the newer ball joints because the spindles are thicker)
Then I used the spindles,tie rod ends,and center link from the 79. I didn't have to change the pitman arm or the idler arm.
Hope this helps.
70 Chevy C/20
72 GMC 1500-SWB
72 GMC K/2500
70 Chevy C/20
72 GMC K /2500
woodmancfh is offline   Reply With Quote
