Old 03-30-2001, 01:07 AM   #1
LeRoy
Registered truck nut
LeRoy's Avatar
Post lowering blocks
Are the lowering blocks the same for a 3/4 ton? Do the U-bolts run through them? The truck is coil sprung in the rear. Thanks
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 03-31-2001, 12:05 AM   #2
gearhead dave
Post
i think so, all though i made my own out of 2" angle iron welded together, all i needed was some longer u-bolts, made my 'burb 2" lower in the rear, had u-bolts made for $36
later
dave
1976 Crew Cab Dually (under construction)
1972 Suburban
1955 Pro Street Chevy
1985 S-10 Blazer (daily driver)
V W Sandrail
Located in Horn Lake, MS that's just 4 miles south of Memphis TN
www.classictruckshop.com/clubs/earlyburbs/members/gallery2/223/display.htm
1972 Suburban
V W Sandrail
Former engine builder for Racing Head Service
Performance Engines in Memphis TN. over 1,600 plus engines built by little ole me!!
GOD BLESS THE BRAVEST OF THE BRAVE...THE NEW YORK CITY FIRE FIGHTERS!!
gearhead dave is offline   Reply With Quote
Old 03-31-2001, 02:14 AM   #3
BadAzz70PU
Long Lost Member
Post
Gearhead, I think you can buy lowering blocks with U-bolts for 20-30.
Tony
1970 C10 LWB
-14.09 @ 96mph
Web Site
1995 Eclipse GSX
-15.46 @ 88mph (stock, not for long)
College student at Clemson (SC)
Home in Langhorne Pa
BadAzz70PU is offline   Reply With Quote
Old 04-01-2001, 09:55 AM   #4
boblor
Wink
The lower blocks need to be made of solid stock, as you drive the truck the blocks made that are hollow will crush some and the rearend will start to twist. You can buy a kit for around 20-30 bucks. BBBob
72 SUB. 402-400 p/s p/b tilt front/rear a/c
boblor is offline   Reply With Quote
