Old 04-02-2001, 01:30 PM   #1
70gmc4me
Post Disc brakes
Hey I got found some disc brakes. He says they are 71-86 1/2Ton Chevy Rotors, spindles, calipers, proportional valve, and master cylinder for $75.00. I have a 70 model with drums. Im guessing they are for a van being those years but I need to know if they will work and if this is a good deal. They look very original meaning they have not been turned in 30 years.
70' GMC......Tank
~Josh~
rollingrn@hotmail.com
70' GMC......Tank
70gmc4me is offline   Reply With Quote
Old 04-02-2001, 01:56 PM   #2
Woody
Post
70GMC4me,
While that is not too bad of a price, I beleive you need the center link, inner & outer tie rods, tie rod adjuster sleeves, and upper & lower ball joints. Also what shape are those rotor in? You don't want to buy them if they aren't in new condition. I would price a whole cross member with the brake booster & master cyc. It should be easier to swap out as a whole, if you can find one in good cond.
Woody
'69 Custom-10 Deluxe
Short Fleetside,Factory 350cid/TH400,A/C,PS,PB,Carpet
Coming soon 700R4, 350 Crate Engine, Pwr Disks...
Woody is offline   Reply With Quote
Old 04-02-2001, 02:29 PM   #3
Southpa
Southpa's Avatar
Post
Get ready to switch to 5-lug rims too.
Southpa
1970 GMC 1500 Custom
Victoria, BC, Canada
Original 350/TH350
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 04-02-2001, 11:35 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I been told, that you'll need to get the steering gear box, and drill a hole too.
'69 G.M.C. 350 W/a heluva cam and nice stance. Still a beater though. If you're into the Longhorn trucks, check out my site, at<A HREF="http://geocities.com/MotorCity/Flats/8752
" TARGET=_blank>http://geocities.yahoo.com/MotorCity/Flats/8752
</A>
Old 04-03-2001, 08:43 AM   #5
Randy70C-10
Randy70C-10's Avatar
Post
Woody is right, It will be much easier to do a complete swap. I just put disc brakes on my 70, I had a complete 72 for the swap. It saved me from the big parts search. Anything bolted to the frame of a 72 will bolt to a 70 with no problems, as long as it's a complete swap.
Randy
70 C-10 SWB Stepside
47 Chevy Fleetline
30 Model A Coupe
87 Harley Sportster
Built in USA!!!!
Randy70C-10 is offline   Reply With Quote
Old 04-03-2001, 09:55 AM   #6
BadAzz70PU
Long Lost Member
Post
is it required to have the engine out for that swap?
Tony
1970 C10 LWB
-14.09 @ 96mph
Web Site
1995 Eclipse GSX
-15.46 @ 88mph (stock, not for long)
College student at Clemson (SC)
Home in Langhorne Pa
BadAzz70PU is offline   Reply With Quote
Old 04-03-2001, 05:45 PM   #7
fleetimus
fleetimus's Avatar
Post
Go with the complete change over. I put the fr xmember from a 75 1/2 tn under my 68. You can completely refurb the assembly and then bolt it in. You have to drill one hole on the frame on each side. It is a lot easier to do with the engine out. Heck, you have to clean up the engine compartment anyway. Get a hold of me if you have any questions.
68 Chevy l/b, 4 whl disc in the foothills of No Calif
fleetimus is offline   Reply With Quote
