Old 04-06-2001, 10:02 PM   #1
ImpalaSS
Post lowering blocks?
wondering if putting lowering blocks ALL AROUND on the 56 would be a bad idea? (on the front leaf spring front end to) what about doing a axle flip on all four coroners? (need cheap ways to lower!)
thanks
www.xframeimpala.com
68 4x4 short fleetside deluxe cab 327 air
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
ImpalaSS is offline   Reply With Quote
Old 04-09-2001, 12:01 PM   #2
BadAzz70PU
Long Lost Member
Post
I dont know about the front, but the axle flip for the back is a cheap way to get a good 6" drop. Thats what I did on mine. Total cost, $38. I made the frame notch kit out of some scrap metal from a local grinding shop and only had to purchase spring perches and U-bolts. I got a friend order them from his mopar dealership. Worked out well and came out cheap, just make sure there is nothing that will interfere, like exaust. I had to cut my exaust off in front of the axle when I first did it until I could get new tubing bent. Good luck. Hope someone else can help you out with the front.
1970 C10 LWB
-Worked 350
-Dropped
-Tangier Orange Paint
Visit my Web Site: www.low70.com
College student at Clemson (SC)
Home in Langhorne Pa
Tony
1970 C10 LWB
-14.09 @ 96mph
Web Site
1995 Eclipse GSX
-15.46 @ 88mph (stock, not for long)
BadAzz70PU is offline   Reply With Quote
Old 04-16-2001, 08:35 AM   #3
Randy70C-10
Randy70C-10's Avatar
Post
If you do that on the front, don't forget about the scrubb-line (will your truck still roll if you get a flat tire, or will the front axle dig into the pavement). Just depends on how thick the lowering blocks in the front are.
Randy
70 C-10 SWB Stepside
47 Chevy Fleetline
30 Model A Coupe
87 Harley Sportster
Self Propelled Lawn Mower
Built in USA!!!!
Randy70C-10 is offline   Reply With Quote
