Old 06-27-2001, 03:23 PM   #1
Protrucks
Post Cross member swap?
I am going to put a 1978 front cross member under my 69 GMC. I know it will bolt up to the frame but what is needed to hook up the steering. will the 69s power steering box work with the 78s suspension? Or should I use the 78s box? and will it bolt up to the 69 frame?
1967 Chevy 1/2 SWB
1968 Chevy 1/2 SWB
1969 GMC Flatbed
1970 3/4 LWB
1972 Chevy Burb
1972 Chevy 1/2 SWB
1972 Chevy Longhorn
1970 GTO
1967 Chevy 1/2 SWB (under construction)
1968 GMC (propane-under construction)
1969 GMC Flatbed (propane)
1970 3/4 LWB (propane)
1970 Stepside 402 (gasoline)
1971 GMC Burb
Protrucks is offline   Reply With Quote
Old 06-27-2001, 05:42 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
the p/s box on the 69 and 78 are exactly the same... use whichever box you want..... also you will need to redrill two new holes in the frame for the crossmember.... easy
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 07-01-2001, 03:01 PM   #3
gotta69bowtie
Thumbs up
I swapped crossmember from an '84 onto my '69. I had to drill one hole on each side, and enlarge one hole on each side...easy. I used the p/s box from the '84, as well as pulled all brake lines, porportioning valve to swap the brakes over from the non-power drums. It was an easy swap.
I did find when adding the '69 p/booster & master cylinder, that the '84 brake line fittings going to the m/cyclinder were reversed from the '69 m/cylinder. I bought adapter fittings to correct this. It works fine.
ken
OK
'69 C/10 LWBowtie
maybe a daily driver, some day...
"Life is not too short, it's just that eternity is so long."
[This message has been edited by gotta69bowtie (edited 07-01-2001).]
ken
OK, 74429
'69 C/10 LWBowtie
could be a daily driver, ... some day ...
"He who dies with the most toys, still dies."
gotta69bowtie is offline   Reply With Quote
Old 07-07-2001, 12:05 AM   #4
Fast68Chevy
Fast68Chevy's Avatar
Post
yeah, and 81-up boxes have O ring style p/s hose ends, unlike the '68-80 common flared style hoses.
Fast68Chevy is offline   Reply With Quote
