Old 07-12-2001, 10:31 PM   #1
1965 C-10
Post How about adding a power booster and dual master cylinder to all drum brakes on 1965
Maybe just putting on the newer power booster and dual master cylinder would help the back brakes from locking up, would it even fit, what kind of modifications will I need to do? 1983 custom deluxe half ton donor truck
1965 Chevy C-10 shortbed fleetside, 327,th350,3.73 to 1
1965 C-10 is offline   Reply With Quote
Old 07-13-2001, 09:19 AM   #2
69panel
69panel's Avatar
Post
You can install the booster and dual master cylinder on your '65 as long as you use the later model proportioning valve. If it were mine I'd put the disc brakes on too.
'52 Buick Special Dlx 2dr. sedan, '68 Camaro
'69 C-10 Panel, '07 Toyota Taco SR-5
"Try to be the person your dog THINKS you are"
69panel is offline   Reply With Quote
Old 07-15-2001, 10:35 PM   #3
drodgers
Post
did my 67 and 70 both with drums it is nite and day difference! should be first thing anybody does!
drodgers is offline   Reply With Quote
