Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Product Reviews
Old 08-14-2001, 10:07 PM   #1
Benrs86
Benrs86's Avatar
Post review on bed wood?
where should or shouldnt i get wood for my bed? oh yeah and bolts and strips too? thanks, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 08-15-2001, 01:57 AM   #2
Mudder
Mudder's Avatar
Post
bought my first wood floor from chevy duty (pine) was really nice. got the stainless bolt kit for the entire bed from LMC. had plenty of bolt (etc) to do the job. the second time i had my wood floor made locally using a chart GMCPaul has on his web site.
67 stepside 4x4 Owensville MO mudder67@hotmail.com
Mudder is offline   Reply With Quote
Old 08-15-2001, 07:23 AM   #3
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Post
I used marine grade plywood(no voids)and treated it with a sealer. Cheaper in the long run and more durable IMO. 2 sheets 90.00 each and about 30.00 in harware. Total $220.00
67
67 Fleetside Custom C-10
SBC 350 .030 9:1 comp.
Comp Cams Extreme Energy XE256H-10
Edlebrock performer intake
Screw in rocker studs
Oversize valves
Scat 350 crank
Everything balanced within one gram.
Marine grade plywood bed(looks awsome)
67Fleetsidedream is offline   Reply With Quote
Old 08-20-2001, 10:47 PM   #4
Benrs86
Benrs86's Avatar
Post
Yeah i saw a pikcup at a car show witha plywood bed and some car body trim spaced about 8 inches apart with some rubber stuff and it looked really nice and kept his wood from getting scratched. i think i will do that. any other ideas? thanks ben
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 08-21-2001, 03:44 PM   #5
Benrs86
Benrs86's Avatar
Post
67fleetside....why did you need two sheets? whats a void? and did you just leave it plain in the middle or did you like put a strip or something and did you put all the bolts it or just around the edges and stuff? do you have any pictures? that sounds like a cheap way that would look really nice. thanks, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 08-21-2001, 07:44 PM   #6
67Fleetsidedream
Post
Ben, 2 sheets are needed. The sheets are not quite long enough to go from the front to the back laying them long ways. So I positioned them cross ways with the wood going left to right.
Voids are the gaps left in the wood by the flaws during processing. If you look at the edge of the lowest quality plywood, you will see places where wood is missing. These holes hold moisture. The moisture causes the wood to mold and break down quickly (i.e. ply’s coming apart) it also allows the moisture to break the glue down. These are the main problems when using low-grade wood. Marine grade plywood is the best you can get as far as plywood. It has very little to zero flaws in the ply’s.
I left mine plain. You can put a plate or something to cover up the gap. It doesn't bother me.
I placed bolts all the way around the out side and then placed two strips of bolts in the middle. I was more concerned about it rattling and the fit to the frame. My main goal was durability and functionality not looks. Before I put the wood in the bed I coated each sheet several times with Thompson super water seal. It is latex based and it also extends the life of the wood.
I do not have a digital camera. So therefore I do not have any pictures. Sorry.
I went this route because I didn’t want spend $300+ on the kit and then be afraid to put anything in the bed. I have a Pontiac 400 big block in the bed right now. If I had the original wood bed, it wouldn’t have anything in the bed so therefore the whole purpose of the truck is lost.
Good luck
67
Oversize valves
Scat 350 crank
Old 08-21-2001, 07:44 PM   #7
67Fleetsidedream
Post
Sorry repeat post.
67
[This message has been edited by 67Fleetsidedream (edited 08-22-2001).]
Old 08-21-2001, 09:21 PM   #8
Benrs86
Benrs86's Avatar
Post
cool. thanks for the reply. i know what ya mean about spending 300+ then not using it or spending 200 and still being able to use it. i dont know what i should do yet though. kinda confusing. thanks, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 08-25-2001, 11:31 PM   #9
rin68
rin68's Avatar
Post
I'm using Chevy Duty pine wood kit and strips. went with plain steel and then painted to match the truck (would post pics, but need to move to free pic site.) then used a Bruce Horkey finishing kit. Shine is great and its been standing up well for the first year.
1968 Chevy C-10, 2wd, wood bed, 327 w/Vortec heads, 600 cfm Holley 4-bbl, Edelbrock Performer RPM, HEI,3-spd stick.
1968 C10 - 383, non-stop project
1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies
rin68 is offline   Reply With Quote
Old 08-26-2001, 09:51 PM   #10
Benrs86
Benrs86's Avatar
Post
ok i think i changed my mind again. my dad is on a business trip in minnesota so he is gonna stop at bruce horkeys and buy the wood and strips and bolts. then i will get mounting bolts and stuff from chevy duty. will that work or are the bruce horkey strips not that good? thanks for the replies, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 08-26-2001, 10:07 PM   #11
Mudder
Mudder's Avatar
Post
try to get stainless bolts when you can even though they are a little higher. well worth the extra bucks.
Old 08-27-2001, 05:47 PM   #12
Benrs86
Benrs86's Avatar
Post
yeah i was planning on going with the stainless. thanks for the reply, ben
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 09-03-2001, 07:15 PM   #13
blue72stepside
blue72stepside's Avatar
Post
I got all my stuff form Chevy duty. All the stuff fit perfect.
[img]http://communities.msn.com/_Secure/0PAAAABQUhUkYrU5OjPjS3yxa93B*cz51*fC7ETN8WsVJypPSwAism2C4WJmf8cmfAPjymJXb3j4o7QyksjvdFGtN2YQTh90v/hi-shot-rear.jpg[/img]
[This message has been edited by blue72stepside (edited 09-03-2001).]
72 Cheyenne Stepside
357/TH350 3.07 Posi
379HP@5500 412FT#@4000
96 1500 Work Truck
88 Chevy Van 3/4
97 Tahoe 8.5 Lift (Sons)
00 1500 LT 4x4 (Sons)
98 Ford Cobra (Wifes Car)
blue72stepside is offline   Reply With Quote
Old 09-03-2001, 10:29 PM   #14
Mudder
Mudder's Avatar
Post
works great doesn't it? nice!
Old 09-04-2001, 06:53 AM   #15
67Fleetsidedream
Post
Blue72, Is that a show truck? Do you think you will ever put anything in the bed? If I had that kit in the bed of my truck, I would be afraid to put anything in there because of the fear of scratches.
I like my marine ply wood bed. Low maintenance and tough.
67
Oversize valves
Scat 350 crank
Old 09-04-2001, 11:52 AM   #16
rin68
rin68's Avatar
Post
Chevy Duty wood with Bruce Horkey finishing kit. It was dusty when I took the pic.
Old 09-04-2001, 10:01 PM   #17
Benrs86
Benrs86's Avatar
Post
Man those are some nice looking beds! I hope mine looks half that good when i get it put together. I wont get mine together for a while...he cant paint it till the end of october..it might take that long to put the SEVEN coates of varnish on. thats a lot i think. anyway, thanks for the replies, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Old 09-05-2001, 09:37 PM   #18
blue72stepside
Post
It wasn't going to be when is start the restore, but it turn out that way. The only thing going in the back is some blankets to sit on at events, and the NOS bottle. I have a 96 chevy pickup and a 88 chevy van to do work with.
[This message has been edited by blue72stepside (edited 09-05-2001).]
357/TH350 3.07 Posi
96 1500 Work Truck
88 Chevy Van 3/4
