Old 01-18-2005, 06:38 PM   #1
1-PU70
1-PU70's Avatar
HEI Power Wire
Can someone with a 75-85 Chevy with a HEI tell me if the power wire to the HEI is fussed and if so what size. Im redoing the power wire to mine and Im running it streight to the Battery with a relay and would like to fuse it. Its in a 70 so I have no idea what size fuse to use.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 01-19-2005, 11:12 AM   #2
60-66 Nut
Professional Beer Tester
I've never seen a fuse on any HEI equipped trucks, they just have a wire strait from the ignition switch to the distributor. The HEI doesn't draw many amps, but it does need a full 12V to it. On the trucks that I converted to HEI, I just used one of the "IGN-UNFUSED" terminals in the fuse block and they worked great. You can put a relay if you like, but I really don't think it's necessary. I've seen guys that even used the resistor wire for the point distributor to run an HEI and never had a problem so they can't draw that much power. Best of luck.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
