Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 11-18-2001, 01:11 PM   #1
68dontneedanewone
Post TECH-FAQ: DiscBrake/Tie-rod End/Interchange
This is the info provided by Fast68Chevy to my questions on tie-rod end interchange when doing a 67-72 disc brake swap.
 67-70 tie-rod ends will interchange.
 71-up tie-rod ends will interchange.
 67-70 ends are too small for 71-up, you must use 71-up inner and outer tie-rod ends when using 71-up spindles.
www.classicperform.com sells a custom tie-rod adjusting sleeve which will allow you to use the stock 67-70 inner tie rod ends/center link with 71-up outer rod ends.
 When using 71-up spindles on a 67-70 (and not using the custom sleeve) you must change the centerlink to a 71-up to allow use of 71-up inner ends, adjusting sleeve and outer ends.
 The pitman arm and idler arm on a 68-up with power steering and a 64-up with manual steering WILL fit into any 71-up centerlink.
 Pitman arms will all fit the centerlinks of all Chevy IFS years with manual steering, and late 68-up with power steering. The splined end for the sector shaft of the boxes differ in diameter between manual steering and early 68-down power steering.
 4x4 boxes wont fit 4x2 arms and vice versa.
[This message has been edited by 68dontneedanewone (edited 11-18-2001).]
Earle - Covington GA
68 Chev SS/SWB: 350-Edelbrock intake/carb, 'built'700R4(kevlar bands etc), front disc, A/C
2002 Silverado CrewCab LongBed
8.1 Vortec
Allison Tranny
68dontneedanewone is offline
Old 11-18-2001, 01:27 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
just to add a bit to the subject www.classicperform.com sells a "sleeve" to use the stock 67-70 iner tie rods and center link
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline
Old 11-18-2001, 02:00 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
the pitman arms will all fit the centerlinks of all Chevy IFS years with manual steering, and on late 68 with P/S, its just the splined end for the sector shaft of the boxes that differs in diamter, thats between manual and power.
That, and 4x4 boxes wont fit 4x2 arms and vice versa.
getting detailed, heh
Fast68Chevy is offline
Old 11-18-2001, 05:21 PM   #4
69 longhorn
Post
a couple more thoughts,the turning radius will be shortened if the 71 lower a-arms are not used when doing a disc conversion with stock parts. also the 73 up spindles can be used, with the corresponding balljoints,& outer tierod end.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline
Old 11-18-2001, 10:09 PM   #5
Dandeluxe
Dandeluxe's Avatar
Question
68 RECENTLY I PUT A DISC BRAKE CONVERSION KIT ON MY 69 CST AND NOW IT SEEMS LIKE I LOST SOME OF MY TURNING RADIUS, MY AMOUNT OF LEFT DOESNT SEEM TO GO AS FAR AS IT USE TO IS IT POSSIBLE I INSTALLED THE WRONG STUFF FROM EARLY CLASSIC CHEVROLET MAYBE WRONG TIE ROD ENDS OR SOMETHING LIKE IT OR PITMAN ARM OR ??? ANY HELP AT ALL OUT THERE IS GREATLY APPRECIATED THANKS, DANDELUXE
1 FINE 69 CST SWB W/ A 350 CORVETTE MOTOR AND ALL NEW FRONTEND PARTS AND A DISC BRAKE CONVERSION AND A 1950 CHEV. PANEL TRUCK
1969 cst swb 350/400 th . DANNY C .
["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!!
1969 cst swb corvette hugger orange with 400 hp sbc
I started out with nothing and i held on to it
Dandeluxe is offline
Old 11-18-2001, 10:17 PM   #6
69 longhorn
Post
I would check to see if your pitman arm is centered on the steering box. the way I check mine during assembly,is turn the steering wheel all the way to lock,then turn it the other way all the way to lock & count the turns. Now turn it back 1/2 the distance,& with the wheels straight, install the pitman on the box. Good luck....Hotrodhorn
Old 02-16-2003, 04:16 PM   #7
72MARIO
72MARIO's Avatar
71-72 outer tie rods are the same
73-87 outer tie rods differ from 71-72.
The sleve your talking about from CCP allows you you to use 73-87 spindle in 67-72 trucks( Ball joint's must be 73-87) 73-87 outer tie rods and 67-70 outer tie rod for use on the inner is the set-up you will need to use Trust ME.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline
Closed Thread
