#1 | |
Bloo
tach doesnt work?!?!
ok, ive got the green wire going to the TACH port on the HEI, ive got the black grounded to a bolt (good ground, got another gauge grounded there and it works) white slid in above panel lights, and red hooked up to a hot spot on the fuse block (hooked a wire up to that spot and sparked it on the door to make sure it was hot), but my tach will not move for anything...what gives?
oh yeah, autometer 3 3/4 inch tach
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
its all about the +6 inches
Double check all your connections. I know I have messed up on the green one more than once. (it felt like it was in)
If all checks out good...sounds like a bum tach. |
huh?
![]() Join Date: May 2000
damn Josh, get a volt meter. Sparking a wire against the door probably blew the fuse.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
#4 | |
Bloo
hehe, i was using some of the unfused ports
![]() climb in there and check out the tach thing on the HEI (having no inner fenderwells is cool for workinng in there)
huh?
it's still stupid IMHO to arc a wire to see if there's juice.....
#6 | |
Bloo
hehe, yeah, it is but i didnt know how that voltmeter worked....and i didnt think it did because it wouldnt show any volts, found out that one was a bad ground. now it reads 16 once the truck gets running, according to my book though it should only have 14-15?
