Old 02-05-2005, 03:37 PM   #1
Sooner1970_K10
1970 K10, 350, 4spd!
Sooner1970_K10's Avatar
Knuckle & lift size question!
I own a 1970 chevy 4x4 that is completely stock. I have been wanting to put a lift, tires & rims on it since I bought the truck last year. Here are my questions. Keep in mind that I wont do much else to the truck for several more years.
(1) Should I keep the stock lift and slap some 31x10.50x15's on the original rims and be content with that for a couple of years?
(2) Should I buy a 4" superlift HD kit (No-blocks) some 33x12.50x15s and a new set of rims?
(3) Should I buy a 6" superlift HD kit (No-blocks) with 35x12.50x15s and new rims?
The way I figure it, the 6" lift kit isnt much more than the 4" lift kit, the tires arent much more and the rims would cost the same. I plan on using a steering stabilizer with whatever size lift I go with.
I know I need a steering arm, what else would I need to do if I went with a 6" lift rather than the 4" lift? I believe I have to get a new driveshaft made or something with a 6" lift, correct?
Does anyone have any pro's or con's for going one way or the other?
My last question is all the lift kits say that I require an (OPEN KNUCKLE) what exactly is this? Is the difference between an open or closed knuckle the boot or housing? I have attached a picture of my truck, maybe someone can tell me as well as point out to me what an open knuckle is? Thanks again.
Sooner1970_K10 is offline   Reply With Quote
Old 02-05-2005, 03:57 PM   #2
LONGHAIR
That is an open knuckle front axle. The closed knuckle type have a ball that is sealed around the axle-joint. You cannot see the axle in the closed knuckle units.
Generally lift works the same as lowering....go with the greater amount the first time. Most people are disappointed by the lesser amount and wish they had gone more. Just be aware of the change you are making to your effective gear ratio with the taller tires.
Most recommend using an off-set pitman arm for any lift above 4". You probably won't need a new driveshaft for 6" especially if it is a LWB truck.
LONGHAIR is offline   Reply With Quote
Old 02-05-2005, 04:35 PM   #3
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Here's a pic of my closed knuckle on my '69...
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada!
- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs
- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 02-05-2005, 04:41 PM   #4
MAC67
" SHOW ME"
MAC67's Avatar
even if you do run four id run some 35 inch tires , they fill out the wheel wells and look way better imo
MAC67 is offline   Reply With Quote
Old 02-05-2005, 07:44 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I have some pics in the link in my signature of my two. On the 71 I wish I had went with 6" of lift.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-06-2005, 12:30 AM   #6
bodazpa
bodazpa's Avatar
71 with 4 and 33`s
Here is a picture of my 1971 with 4 in and 33 in tires. I'm happy with it.I guess it really depends on you.....John
71 chevy 4x4 ,np205 transfer case, 3 speed tranny, sjs 283, 4in suspension lift, and 71 hugger orange paint,33x12.5 parnelli jones on 15x10 m/t classicII, cowl hood,new bed painted, linex liner. Truck has been completed since 2005....
2003 Chevy Avalanche Z71, on 6in super lift w/ 35in tires
RNG4x4 aka the "Redneck Roller"
words to live by "If it fits, it fits"
"friends help you move, real friends help you move bodies..."
Sponsored by "Kick Ass Kustom"
bodazpa is offline   Reply With Quote
Old 02-06-2005, 01:43 AM   #7
4x4Poet
Steering stabilizers are something of a marketing scam. Usually, steering stabilizers are only needed when there is something wrong with the steering, suspension, or tires & rims. Bump steer is the most frequent fault that motivates some 4x4 owners to install a stabilizer. The dropped pitman arm Longhair mentioned would probably eliminate any bump steer encountered without one on 67-72 GM trucks lifted 6" or less. Large radial tires rarely need one, but large, agressive bias tires might if they come from the mold out of round, uneven weight, etc. So, if after lifting your truck you think you need a stabilizer, look into whether the set up is right first.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-06-2005, 01:43 AM   #8
MAC67
" SHOW ME"
MAC67's Avatar
now that aint fair john , you could knock the tires clear off that truck and set it on the hubs and its still gonna be absolutley gorgeous , wow , you cannot beat an orange short fleet 4x4 they will always hold a special place to me , wow , absolutley gorgeous
Old 02-06-2005, 02:48 AM   #9
Sooner1970_K10
Ok thanks for the info everyone. So I have seen a couple pics of 67-72 trucks with 4" lifts, does anyone have some of 6" lifts?
Old 02-06-2005, 03:09 PM   #10
1FaastC10
1FaastC10's Avatar
Sooner, i think everyone here has forgot one very important element of building a good usable 4x4 truck.
What gear ratio do you have? if you have anything higher than a 3.73, do not lift it or install bigger tires. doing so will turn it into a gutless pig, and it will drink gas like no other. you'll hate driving it because of this.
1FaastC10 is offline   Reply With Quote
Old 02-06-2005, 05:16 PM   #11
Sooner1970_K10
Ok thanks for the tip. Would anyone know exactly what a stock 70 4x4 1/2ton pickup came with in 1970? This has a stock 4 speed manual tranny will that make a difference in its performance? I think when I measured the tires that are on there now, they were around 29". This truck wont ever see the mud. It will be a weekend driver and occasional boat or merchandise hauler from town. I want it to handle and perform well but do not intend to go off-roading in it.
Old 02-06-2005, 08:23 PM   #12
1FaastC10
1FaastC10's Avatar
regarding your use of it, too tall a gear will make it undrivable anywhere, not just offroad.
Old 02-06-2005, 09:40 PM   #13
1969 GMC
1969 GMC's Avatar
my vote would be to do option #1, and then save up for everything later.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-09-2005, 01:07 PM   #14
big70chevy
Tristan's monster truck!!
big70chevy's Avatar
Here is a pic of my '70 before I tore it apart. Here it has a 6" lift and 35's.
1970 K20, 15" lift, 44" Boggers, 14" Weld Scorpios, 5.13 gears.
1993 K1500 ext. cab Z-71
1984 GMC C30 dump
big70chevy is offline   Reply With Quote
Old 02-09-2005, 01:37 PM   #15
Truckstuff
Truckstuff's Avatar
Gear Ratios. Check if you still have the Service Parts Identification Decal in the glove box for RPO Codes. H01 = 3.07, H05 = 3.73, H04 = 4.11 There is also a axle code number stamped on the bottom of the left or right axle tube beside the carrier housing on the rear diff. Eg. TDG = 3.07, TDF = 3.73, TDJ = 4.11 there are more codes. The only way to tell for sure is to take the diff cover off and check the codes on the front of the ring gear and divide them. Eg. 41-11 = 3.73
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 02-12-2005, 11:44 AM   #16
Sooner1970_K10
Well I checked and either its not there or I am crazy! I have my SPI, infact I have provided a picture of it below in case I am not seeing where it tells me what my rear diff is, someone can point it out?
I also climbed up the rearend and looked for about 10 mins for the stamped axle code. The only numbers I saw were on the drivers side of the housing and went like this:
1 2 3
6 7 8
Any other ideas? If I take the back plate of the housing do I need a new gasket of just a silicone bead? I.E. which would be the correct method.
Old 02-13-2005, 03:13 AM   #17
Truckstuff
Truckstuff's Avatar
No diff code, might mean 3.08's. Before you pull the cover, check your front cover and see if it has a metal tag attached to one of the cover bolts, it will have the ratio on it. A gasket or silicone will work to seal the cover.
1985 GM K3500 3+3
1981 GM K2500 SSB
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Old 02-13-2008, 03:19 PM   #18
vanislejimmy
Re: Knuckle & lift size question!
I have a '70 blazer I'm looking at putting a 6" or 8" lift in it. It has closed knuckle steering. What do I need to do for the conversion to open knuckle?
vanislejimmy is offline   Reply With Quote
Old 02-13-2008, 04:28 PM   #19
earl87gta
earl87gta's Avatar
you would have to change the axle to a open knuckle axle from a 71 up 4x4.
if it was me i would go big i have 6 now and wish it was 8. for steering I would not wast money on a drop pitman arm or a rased steering arm if your going to go 6in or more I would just put that money twards going to crossover steering with the cost of the arm and the steering stabilizer you would almost be at the same price any way and it still would not be as good of steering set up. here is a pic of my old blazer with 6in lift and 3in body lift and 36in tires
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 02-16-2008, 12:12 PM   #20
wibilly
wibilly's Avatar
i vote for #1 i'm not one for big tires and a lifted truck for highway use but like the way they drive and perform at stock hight with 31s way easier to load if you use it as a truck too
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 02-17-2008, 01:03 AM   #21
LONGHAIR
A 3 year old post...to the day. I am always amazed at how new guys surf through the old stuff. It's cool to actually search....
Oh....I did mention gear ratio, so it wasn't everyone
BTW, welcome to vanislejimmy
Old 02-17-2008, 02:14 PM   #22
earl87gta
earl87gta's Avatar
I ddint even notice that. I never pay atention to the dates.
Earl
Old 02-17-2008, 09:57 PM   #23
LONGHAIR
I don't always notice the dates either, but I remember that post. It is far easier to notice it when you have posted to the thread when it was new.
Old 02-19-2008, 11:24 AM   #24
CDA 455
MidlifeCrisisUnderWay
CDA 455's Avatar
His last presence:
Last Activity: 08-16-2006 04:04 AM
DIY4X
1972 CST Blazer <---sold
CDA 455 is offline   Reply With Quote
