WANTED: 55-57 GMC Gauge Bezel
Want to buy a bezel assembly for a 55-57 (58-59?).
I have a spare original style dash gauge bezel panel(s) assembly for a 55 GMC.
I believe that the 55,56 & 57 GMC used the identical dash assembly (uncertain about 58-59). I also have spare original gauges. Let me know exactly what you may be interested in. Sorry, I don't have a camera or pictures for you. |
Hi S/S, I sent you a pm. Thanks
I got your pm. Sent you additional info via pm.
Are you interested in a factory clock to go in that dash?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
Thanks for the offer, but I've got a 6pc gauges for the bezel so I won't need a clock.
Hey S/S, I'd like to get a price for you assembly. Thanks |
Did you check the www.1955gmctruck.com web site for a picture of the dash assembly, as I suggested in my pm the other day?
If you are planning to use aftermarket gauges, they more than likely won't work in the factory dash asembly set-up. You may be better off fabricating a new dash "bezel plate" to fit your new gauges. |
Sorry, the correct web address is www.1955gmc.com
Last night while looking there was a decent set on eBay.
Unfortunately, I'm not familiar with the GMC bezel but here's the pics that S/S referred to. As I understand it, I'll need the plates but where do I get the outter trim? It would be nice if I can just buy the complete stock bezel
OK, I will try to explain the dash assembly components.
2 (right & left) DIE CAST MOUNTING PLATES. The gauges are secured to the backside of this, on several bosses or pads which have tapped holes for gauge clamps & fasteners. 2 (right & left) SHEET METAL DECORATIVE PANELS. These are located on top of the mounting plates. The sheet metal is bright & shiny with the horizontal stripes. The trim piece that you refered to is actually the edge of the die cast plates under the sheet metal panels. 6 GAUGE BEZELS. These are the decorative rings around each gauge. If you are using aftermarket gauges that are a different than the factory gauges, I would be easier to fabricate a new dash panel rather then modify the original one |
Thanks for the excellent descriptions.
#13 |
The plates very being reproduced, but are not longer available in stock configuration. The seller, Ken from Florida, I can get you more information if you want it, still has a couple of non stock sets left.
The bezels came in both white and chrome. Here is a look at mine.
#14 |
The Dolphine 6 gauge set I have measures 3-1/8" for the Tach and Speedo, 2-1/16" for the gas, oil, temp and fuel. What size holes are in the decorative panels?
I'd like to get a pair of the decorative plates and the trim piece. |
#15 |
Unfortunately, the aftermarket gauges are a different diameter.
The stock speedometer & bezel is 3.80" diameter. The stock smaller gauges & bezels are 2.20" diameter. I know of no aftermarket gauges, that will interchange with the stock bezels or dash assembly confiruration without some modifications. |
#16 |
See that "white" fluffy thing flying in the ring???
That's the towel I'm throwing ![]() Thanks guys |
#17 |
Yeah your gauges are to small to work in the stock assemble. Don't give up yet!
I am planning to fabricate my own dash instrument panels to fit aftermarket gauges. I think that you can do the same, with some small amount of work. Right now I am in the market for a gauge set, before I start the panel fabrication. Can you tell me about you gauges & why you pick them to buy. What should I look for in a good gauge set? |
