Old 02-24-2005, 01:18 AM   #1
Jimmy72custom
Jimmy72custom's Avatar
I used weather stripping made for the bottom of a garage door. It is easy to find, looks and works well.
Jimmy72custom is offline   Reply With Quote
Old 02-24-2005, 05:49 AM   #2
RED72blazer
urban fourwheelin
RED72blazer's Avatar
what did you use between the gas tank and the gas tank straps?
what did you use between the gas tank and the gas tank straps? I'm not really sure were to look for it or what it is called. thanks red
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 02-24-2005, 06:14 AM   #3
71jimmy
71jimmy's Avatar
I re-used what was under my original tank. After cleaning it thoroughly, it looked like new. I had thought about using cut up inner tubes, from a bicycle, if they hadn't been good. LMC sells a "gas tank anti squeak kit", pg 123 item 6 on the bottom of the page. It's 6.95.
The Truck Shop sells a "Gas Tank Mounting Cushion Set" for $11 on page 107 of their catalog, but it says its for 60 -66 and has four extra pieces. Looks like it might work but not sure.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 02-26-2005, 09:38 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I used some tar strips similar to what it came with.... Got em at lowes I think...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-28-2005, 03:37 AM   #5
RED72blazer
urban fourwheelin
sounds like I'm going to the hardware store on monday
