Old 02-25-2005, 01:34 PM   #1
BUFFB
BUFFB's Avatar
Question 3/4 ton axles or not
My blazer now has drums all around and I was looking to get discs in the front. I have axles from a 3/4 ton 77 chevy truck with discs in the front and 14bff in the back. My only question is can I find 8 hole 15" rims to fit my 33x12.5's. and the drums in the rear . If so where. Thanks alot.
1970 BLAZER
STOCK 350 AND TH350
FIRST VEHICLE
HAD FOR 10 YEARS
STARTING REBUILD THIS YEAR
BUFFB is offline   Reply With Quote
Old 02-25-2005, 01:58 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
You shouldn't have a problem finding the wheels. Just about every wheel dealer should be able to get wheels that fit. Some styles may need to be machined out to fit over the larger style hubs - but I'm not sure if that is relevant for the '77 axle. You'll probably have to move the spring perches.
Swapping disc brake setup from a '71 or '72 1/2 ton should be fairly easy too. Your '70 should have open knuckels. I think there are after market kits available too.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-25-2005, 02:04 PM   #3
BUFFB
BUFFB's Avatar
I've read that I shouldn't have to move the perches on any 3/4 ton axle from 69-78. Am I wrong.
1970 BLAZER
STOCK 350 AND TH350
FIRST VEHICLE
HAD FOR 10 YEARS
Old 02-25-2005, 02:48 PM   #4
bouncytruck
SKINNY TIRES RULE!
I am probably wrong. I thought that the frames on the later modeles were wider. There are a ton of K5's with 3/4 and 1 ton axels, so it is definately possible.
bouncytruck 1972 K5
Old 02-25-2005, 06:16 PM   #5
Scrubby
Check out GMTrucks.org
The front axle bolts right up. I have a '76 dana 44 in the front of mine.
I don't think the 14 bolt does though. I think you have to move the spring perches.
Scrubby is offline   Reply With Quote
Old 02-25-2005, 06:34 PM   #6
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
Go to Austink5.com - someone is making that conversion on that site on a daily basis. Also ColoradoK5.com.
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
Old 02-25-2005, 06:40 PM   #7
BUFFB
BUFFB's Avatar
You guys are right the front does but the 14bff doesn't, I just can't read I just have to read more carefully thanks for the info
1970 BLAZER
STOCK 350 AND TH350
FIRST VEHICLE
HAD FOR 10 YEARS
Old 02-25-2005, 09:13 PM   #8
J.Lance
Too many is never enough!
If you can round up a 14 bolt out of a 1 ton, it will bolt right up, 3/4 will not. You'd just have to relocate the shock mounts. As long as your front end has the small hubs (it should), 15" wheels should go on no problem. Guys who swap in Dana 60s need to grind the caliper a bit to fit a 15" wheel. Like was mentioned before, 15" 8 lug wheels are readily available new and even came stock on some pre '71 special optioned 2wd 3/4 tons. Hard to find those though.
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
