Old 06-19-2002, 06:47 PM   #1
Squeak
Question Hi & an axle question :)
Hiya Just found these boards and hoping some of you might be able to help.
I need to know what axles came in Chevy trucksand what years and models they where in.
gearing doesn't matter, but I need to find out the bolt patterns.
But, I mostly need to know where I can find out what they use from the factory in front and rear and the years.
Hope that makes sense
Kate
Squeak is offline   Reply With Quote
Old 06-19-2002, 07:33 PM   #2
misfits
misfits's Avatar
1/2 ton axles have 6 lugs. 1 ton axles have 8 lugs. not sure about 3/4 ton I think they are 8 also. If i'm not mistaken all chevys are that way.
1/2 tons usually have Dana 44 front and 10 or 12 bolt rears.
1 tons have dana 60 front and dana 60, 70 or 14 bolt rears.
I don't know anything about Eaton axles though. I hope this helps a little.
Can somone help me out here?
misfits is offline   Reply With Quote
Old 06-19-2002, 10:41 PM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
in 67-72 1/2s had dana 44 front, 12 bolt rear same but later on around 79 or 80 they went to 10 bolt front 10 bolt rear.....
3/4s are 8 lug and have dana 44 front and eaton rear i think SOME had rear dana 60s?
73+ they had dana 44 and 14 bolt FF rear......
1 tons had dana 60 front and 14 bolt FF rear
68SWB4x4 is offline   Reply With Quote
Old 06-20-2002, 12:52 AM   #4
Scrub
Collector of rusty Items
Scrub's Avatar
That probably is a bit confusing. A 10 bolt rear has 10 bolts holding the rear cover on the Differential, not 10 bolts hoding the wheels on.
Just checking
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 06-20-2002, 01:55 AM   #5
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
good point, i should have clarified that!
Old 06-20-2002, 05:40 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Some more usefully info:
Dana 44 8.5" ring gear front or rear, rear were mainly in leaf sprung GMCs(67-72) pre 72 in front had small 260X ujoint went to 297x ujoint in 1973. Dana44 last used in approx 1978. Semi-floating except front.
10 bolt(GM axle) 8.5" ring gear front or rear, this axle and a 44 in the front are relatively the same strength wise. And have some interchangeable parts. Came out in 1973. Semi-floating except front.
12 bolt(GM axle) I believe 8.75" ring gear. Used in the rear in 1/2 ton trucks 67-72. Not positive. Full floating
Dana 60 9.75" ring gear. Used in 3/4 tons out back from 67-72. In the front has 332x u joint. Was used it the front from 78-?.
Eaton rear ?-72 has a cover w/ 10 bolts and drop out center section. 3 different ratings with correspondingly larger ring gear. Not parts readily available. Highest gear is in the high 3s (like 3.90:1 maybe 3.73). Lots of low gears. Full floating.
14 bolt(GM axle) two versions full floating(FF) and semi floating(SF). FF has 10.5" ring gear came out in 73 in the rear of 1 ton trucks. SF had a 9.5" ring gear and was used in 3/4 ton and light 1 tons from I want to say some time in the late 70s early 80s.
Dana 70 also 10.5" ring gear as strong as a 14 bolt FF mainly in dually configuration not sure of the year.
FF- bearings carry load of vehicle(desireable) If axle breaks tire is still attached to vehicle.
SF-Axle shaft is intergal part of load carrying there for is subject to more stress. If the axle breaks there is a good chance the tire will leave the vehicle.
I'm going to double check this when I get home from work and correct as neccesary. Let us know what your looking at and we can go from there.
Welcome to the board! It's addictive!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-20-2002, 09:52 AM   #7
HeavyK20
HeavyK20's Avatar
I have 2 chevy 3/4 tons (69 & 70) with Dana 44 fronts and HO72 Eaton Rears. I also have a 71 GMC 3/4 ton Frame with a Dana 44 Front and Dana 60 Rear.
Were the 67 & 68 Closed Knuckle fronts Dana 44's?
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 06-20-2002, 10:56 AM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Yes they were and apparentely some 69s also came with closed knuckle 44s.
It seems GMC came with Dana 60s more often in the rear.
Old 06-20-2002, 02:39 PM   #9
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
67-69 trucks had closed knuckle front dana 44s, 69 blazers had open knuckle dana 44s
