Old 06-21-2002, 01:04 AM   #1
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
Unhappy $1200 later, I still can't get a break..
Ok, went into the tranny shop this afternoon, and the truck was done. Hooray! And it came to a total of $1246. Boo. Oh well, I've got a fresh tranny and driveshaft now, and no college fund left.
Before I leave, though, the tranny guy says something to me.. "I noticed your exhaust had a little crack in it. Might wanna check it out." Didn't really think much of it, and I start it up.. BWUUMUMUMUM! What the hell? Why is it so loud? Pop the hood, look around a bit, and I notice THIS:
What the hell? How did that happen? It sure wasn't like that when I had it before! The tranny guy said he noticed that when he first got it, but I dunno. I don't see how a tranny guy could break an exhaust manifold.. maybe the tow over broke it. Maybe it was already cracked and just ready to break. I dunno.
Not very cool, though. I just noticed the plug boot on the right is sort of melting from the heat. Not cool either. I don't even know how the bottom half of the manifold is still held up there - it's pretty much separated from the top. Can't be good for my engine to run like this.. though I drove it the 80 some miles from Portland to here, and the engine was running fine.. a little on the warm side, and sure was backfiring a lot, but it was running. Thought I was gonna get pulled over it was so loud. The white flames shooting out the gap kinda look cool, though.
I think I'm gonna buy a Honda Civic..
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 06-21-2002, 01:13 AM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
Crud,
It isn't out of the question that the tranny guy unhooked the back of your exaust and broke the manifold off. I would look at the bolts that hold it on and see if they have been taken off. If so, I would ask him about it.
You just paid him a pile of money (Too much by my standards) and he should stand behind it if he broke it.
Is that a right side of a 350? I might have one I can let you have. You aren't too far away.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 06-21-2002, 01:20 AM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
yeah id beat 100 the tranny guy broke it.......
but sounds like time for headers!
68SWB4x4 is offline   Reply With Quote
Old 06-21-2002, 01:27 AM   #4
Patrick Sullivan
The bolts on the exhaust hangers are untouched.. the only thing I can think of is that he jacked the back of the engine up to get the tranny out, and it broke then. I called him when I got home, talked for quite a while, and he denied any involvement in breaking it. He said any tranny problems I had, he will set them straight, but he is not responsible for anything else.
I.. well, bleh.
Old 06-21-2002, 01:35 AM   #5
Paul Clark
Had a new exhaust put on once. Everything was fine until I pulled up to a stop light and thought I got hit by a Scud missile. The manifold broke off at the same place yours did.
Bet something got "tweaked" someplace.
Why do those manifolds break so easily?
Hell, they're only 30+ years old.
Paul Clark is offline   Reply With Quote
Old 06-21-2002, 01:36 AM   #6
68 Suburban
68 Suburban's Avatar
When I had my trans redone, there was a big sign on the wall said that they were not responsible for any damage to exhaust. I guess shows that it is very possible it happened whilte he was working on your trans. Which exhaust manifold is it?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 06-21-2002, 01:51 AM   #7
Patrick Sullivan
It's the passenger side manifold, 2WD.
I guess I shouldn't be suprised that it broke.. but why does everything have to break at once?
Old 06-21-2002, 01:57 AM   #8
68 Suburban
That is the way life is. There was a cheap one on ebay, but I don't know if it is still available.
Old 06-21-2002, 03:01 AM   #9
WORNBRAKES
when i replaced my trany, i loosened the tail pipes at the exh man and disconnected the rest of the way back. i had to move the pipes outbrd to get the trany in and out. sounds like trany man forgot to do this. i would talk to him and if nothing else, chew his a$$. best of luck.
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 06-21-2002, 03:06 AM   #10
Patrick Sullivan
Well, the way my exhaust is routed I don't think he would have had to move it. I chewed his ass some, but I got tired of yelling at a brick wall so to speak, so..
On a similar note, am I going to ruin my heads/valves/whatever if I drive around like this for a couple of days, before I can get it fixed?
Old 06-21-2002, 03:11 AM   #11
WORNBRAKES
i dont use headers but i know that some people use some sort of wrap on them sometimes. maby you can use this and wrap it around the crack until you can replace it. maby, i dunno?
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-21-2002, 03:16 AM   #12
Paul Clark
The wrap is kinda expensive. Think they use it to keep the heat levels down. Have heard that it also promotes rust.
How about an empty beer can and a couple of hose clamps?
Kidding - but I did do this once.
Ahh - youth.
Old 06-21-2002, 03:26 AM   #13
WORNBRAKES
Paul- thanks for that! I will keep that in mind if I ever run into that situation. I like it!
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-21-2002, 06:42 AM   #14
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I'd bet the tranny guy broke it. Probably didn't support the engine when he took out the trans.
That sure is alot of money for this kind of job.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-21-2002, 09:52 AM   #15
ThreeQuarter
ThreeQuarter's Avatar
I'm with Bob. I saw a mechanic do that with my '92 once: he dropped the tranny and let the exhaust support the engine. He said he does it all the time and it was OK. (I didn't agree.) Good mainfolds usually hold up under the weight.
So you have to consider that it was probably time for a new one anyway, if it was that weak to begin with. A couple of weeks ago I replaced a pass. manifold that was cracked in the same spot about 3/4 way around. The owner hadn't had any engine or tranny work done in years.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 06-21-2002, 10:04 AM   #16
cheyenne10
cheyenne10's Avatar
I've had at least 2 jobs by tranny shops disturb the exhaust setup some how (none this severe) and both times they fixed it. One I supplied the new manifold and they installed the other was just the old donut gasket. Any time the engine is moved up or down with exahust hooked up this can happen. I would push them once more for repair of it and offer the repalcement part to do the job, although you are 80 miles out? I would also avoid driving it much as this causes improper cooling of valves and head. Check to see if they have a contact on the coast that they can cut a deal with to get it fixed where you are. Take Scrub up on his offer for manifold unless you have one. Good luck. By the way would you be willing to tell me the name of the Portland tranny shop?
Bob
cheyenne10 is offline   Reply With Quote
Old 06-21-2002, 10:08 AM   #17
Woody
Ya the tranny guy broke it. It wasn't that load when you brought it there, was it?? 5 to 1 he dropped the tranny cross member and didn't loosen the exhaust. When the engine tilted back it broke the manifold. A lot of newer cars/trucks have spring loaded bolts holding the the pipe to the manifold allowing for some give. you may have had a small crack already...who knows.
A quick fix is get some baling wire and wrap around the pipe/bottom part of the manifold and then over the top part pulling it together. Use JB Weld on the seam (before pulling it together) then let it set up. It won't look all that great but will buy you time until you gete another manifold.
Don't forget to inspect your left side also. He may have cracked it.
Woody is offline   Reply With Quote
Old 06-21-2002, 02:29 PM   #18
Sheenanny
He probably loosened the pipe to get the tranny out, then tightened it back down real good. Then as soon as it got some pressure and heat in it, it crashed. Same thing happened to me, same place and everything. I'm sure it was cracked when you took it to him though, so it was just a matter of time. Check junk yards and engine building shops in the area. Those things should be all over the place for 10 or 15 dollars.
Sheenanny is offline   Reply With Quote
Old 06-21-2002, 03:46 PM   #19
68 Suburban
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1838373921
Old 06-21-2002, 04:42 PM   #20
Scrub
Scrub's Avatar
I wouldn't fdrive with it broke that way, You might warp a valve, plus your hearing will fail...
I said !"Your Hearing will Fail!
"Youre gonna go deaf!"
Shut that damn thing off!!!
I think I got an extra manifold, I will email you
Scrub
Old 06-21-2002, 04:56 PM   #21
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
My old Longhorn was the same way.
The engine not being held up by a 3rd mount WILL do this. They are supposed to support the motor instead of letting it tilt back.
I would contact the BBB in his area, and your State Attorney general.
They will knock some heads together and see if they can't make things right.
Old 06-21-2002, 05:06 PM   #22
Scrub
Scrub's Avatar
Dang,
I looked all over and couldn't find a manifold,
Sorry
Scrub
Old 06-21-2002, 05:07 PM   #23
68 Suburban
Is every trany shop shady?
Old 06-21-2002, 06:01 PM   #24
COBALT
COBALT's Avatar
Speaking as a Mechanical Engineer your picture actually tells you what happened.
This is the passenger side? If so then it was broke by jacking the engine up too much!!! How do I know? Well, let me tell you!
Does everyone see how straight the fracture is on the back part of the break (the rear of the manifold)? Generally you'll see straight fractures like that in the case of brittle tension fractures, where forces pull members apart. On the other side of the break is the opposite, or brittle compression where two members are pushed together. Typically this makes jagged breaks where material is sometimes chipped out, like the front part of the break.
Since the manifold was so old anyway (and probably rusting pretty badly) all it took was enough torsion (to make the engine rotate forward) to break the manifold.
The bottom line is he did jack the engine up, but he did it too much.
You can experiment with this by taking a piece of chalk and bending it until it breaks. The bottom of the break where the compression will be jagged, and the top part of the break under tension will be flat and clean (compared to the bottom).
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-21-2002, 06:28 PM   #25
Stout72
Not my good side.
Stout72's Avatar
New69 is 100% correct. You have a classic stress fracture. I've seen similar fractures like this on shipboard equipment in my profession as a Marine Engineer. Your tranny mechanic would have advised you of that break before he started work, if he was an honest man. It appears he doesn't want to own up to his mistake.
If you need to run the truck, you better cover it up with something or cool air will find its way in to your exhaust ports and warp your valves. Someone suggested a beer can and hose clamps, sounds like good (although temporary) damage control to me. If you can find a piece of insulating blanket that welders use to protect surrounding areas from slag and sparks, wrap it with that first. Then use 2 beer cans.
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
