Panel Truck rear body mounts
Hey all. I'm back to the blessed AD trucks! I had a slight folie and commited adultry with the 60-66 trucks but I've since recovered from my blindness and returned! Anyway, I'm getting back into my 53 GMC panel project and there is a question that is lingering since I started the project. The body mounts for the rear of panels. Any body have photos? My frame was modified by the p.o. and they seem to have forgotten to put them back on! Any help would be nice since I don't want my body flopping all over as I drive!
PanelRodder 1953 GMC Panel Truck 1966 Chevy C10 www.brigham.net/~jacobh/barndoors/index.htm |
Street Rod Dreamin'
Location: Work:Batam, Indonesia/ Home:League City, Texas
I'll have to look back through some old pics. I was just looking on my site and there's one that kinda shows one of the blocks but, not very well.
I'll see if I have anything.
1954 Chevy 3100 Panel Truck 2004 GMC Yukon 2007 GMC Sierra 4X4 "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it." Benjamin Franklin, On the Price of Corn and Management of the Poor, November 1776 |
#3 | |
Thanks so much. I was begining to think that no one could understand my ramblings! Anything would be of use at this point. I am about ready to just develop something from scratch!
Who's in CHARGE??????????
basicly the bodies are bolted in 3 spots (not including where its bolted down through the wood floor), they are at the front of the cab down by ur feet on both sides, then there's a pair rite behind the front seats, then the last pair is at the rear doors on the sill.the front one are bolted to bracket attached to the frame the rest are bolt through the frame. here's where they are on my 48 chevy so i would bet they ar the same. if ur wondering where on the wood floor they are mounted just look up under the floor & u'll see the bolts running down through the floor & all the way through the frame, about every 2 feet, i believe..joe
Send a card to a soldier in Iraq My Music PlayList Large Marge Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE Last edited by TooMany2count; 07-18-2005 at 11:58 PM. Reason: once upon a time long ago in the land of make believe, there was this young man that abused his body & 2day he does forget things at times. just like i just did, so i had to edit my post. the end |
Street Rod Dreamin'
Your right, Joe. I couldn't find any old pics but, my body is still on the frame and I can snap some new images tomorrow and attach to the thread. Left my camera at work today.
I come out to Utah every once in a while for work. I fly into SLC and drive over to Altamont. Looking up Logan, it looks like up about 4 hours north?
#6 | |
#7 | |
Logan is actually only about two hours north, close to 1 1/2 if you know were the cops sit!! It looks like a lot longer drive on a map than it really is. The freeway speed hits 75 when you get north of Ogden, which means that 85 is ok!!!!! What type of business brings to you SLC?
the rear mounting points on the stock frame went through the frame at the rear. the ONLY brackets attached to the frame are in the front...joe
Send a card to a soldier in Iraq My Music PlayList Large Marge Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE |
#9 | |
Street Rod Dreamin'
![]() I'm a data/communications supervisor for an energy company. Poor lighting in the garage tonight. The images didn't come out clear enough to really show things like I wanted. I've got a light out in the shed that I'll drag in tomorrow and get some quality pics for you.
1954 Chevy 3100 Panel Truck 2004 GMC Yukon 2007 GMC Sierra 4X4 "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it." Benjamin Franklin, On the Price of Corn and Management of the Poor, November 1776 Last edited by 3100 special; 07-19-2005 at 10:24 PM. |
#10 | |
That is what I was afraid of. I will have to look closer at my frame and see what I can come up with. I may just be remembering it wrong. My truck is coming home on saturday morning so I should have a fresh idea then!
just take a piece of square tubing & cut it at an angle and make a mount. this pic will give ya an idea what i did to the rear of mine since its on an s10 frame
#12 | |
That will be perfect! I was kind of imagining something along those lines but hadn't taken the time to really visualize how I was going to make it. That simplified it a bunch thanks! ![]() ![]()
#13 |
Street Rod Dreamin'
First let's see the pics and I'll come back and edit....
Ok, that works. The pic on the left is when the carrage bolts go down from the back edge of the seat deck. This bolt did pass through the wood plywood that used to be in the rear. The pic on the right, shows two arrows. The one on top is where the carriage bolt went down through the back plate. The second arrow below shows how the bolt dropped down after I ground the head off of the bolt. You can see an area directly in front of the area where the bolt passes through the frame that is a lighter color. This is where cross member (?) pieces where bolted on to the frame. The wood in the back of the truck rested on these cross pieces. The pics on my site still show these cross pieces in place. This help? Looking at Joe's site, he came up with a great way of using steel tubing to build a dang sturdy base...and add a little weight....his truck looked too light anyway..... ![]() You may have to build yourself something if the previous owner went too far with their mods. ![]()
1954 Chevy 3100 Panel Truck 2004 GMC Yukon 2007 GMC Sierra 4X4 "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it." Benjamin Franklin, On the Price of Corn and Management of the Poor, November 1776 Last edited by 3100 special; 07-20-2005 at 08:13 PM. |
