Old 04-13-2002, 04:28 PM   #1
Dandeluxe
Dandeluxe's Avatar
Question ?alternator conversion to buit in regulator???
i know this is probably an old topic . my alternator is bad and when i go to an auto parts store to get one should i get a newer model so i can convert to a alt. with a built in regulator. or what is it i need to convert my 69 cst to an alternator with a built in regulator?.
1969 cst swb 350/400 th DANNY C. ddclux@aol.com st. louis mo.
for pic.s go to http://community.webshots.com/user/dandeluxeGO TO Fotki. com for public pic.s under DANDELUXE
I started out with nothing and i held on to it
1969 cst swb 350/400 th . DANNY C .
["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!!
1969 cst swb corvette hugger orange with 400 hp sbc
Dandeluxe is offline   Reply With Quote
Old 04-13-2002, 07:37 PM   #2
Dandeluxe
Dandeluxe's Avatar
Cool
ttt
Old 04-13-2002, 07:41 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
You will need the later model pig tail, aither from a junk yard, or the help section, I am not quite sure which way to wire that one up, and you'll also need some wire and crimp on connectors for the old regulater.
The new alt will bolt right in place of the old one, wire it all up, then when you get to the old reg, wire it up like this;
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-13-2002, 07:46 PM   #4
Dandeluxe
Dandeluxe's Avatar
Question
andy, thanks for the pic. will i need to hook up only one wire on the new style alternator? a mechanic friend told me to get a one wire alternator. ????
Old 04-13-2002, 07:49 PM   #5
Longhorn Man
Post
That is an aftermarket deal there, I know nothing about them.
Old 04-13-2002, 08:42 PM   #6
Mike C
Mike C's Avatar
Post
Here is a link to a FAQ that has a good conversion process.
http://www.ucalgary.ca/~csimpson/Tech/RConvert.html
This one has lots of info and claims external regulators burn up HEI modules. http://my.inil.com/~dlbrown/ofign.htm
And this one is probably the best: http://www.442.com/oldsfaq/ofall.htm...r%20Conversion
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
Old 04-13-2002, 09:00 PM   #7
Longhorn Man
Post
B.S. Been doing it for years, and have yet to have HEI trouble.
Old 04-13-2002, 10:07 PM   #8
Als454
Post
Retrofitting SI-Series Alternator,
At the Regulator:
1. White wire cut and tape (not needed)
2. Red wire cut and tape (not needed)
3. Cut the Blue and Brown wire and splice
them together.
At the Alternator:
1.The plug has two wires in it. The blue wire
is the one you spliced to Brown wire at
the regulator and nothing needs to be
done to it. The white wire however was cut
at the regulator and should be rewired to
the battery terminal on the alternator.
Hope this helps? I did it on my truck just recently. Went the extra mile and chased cut wires back through the harness to pull them. Removed the regulator and threw it away.
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
3" Exhaust W/Headers
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 04-13-2002, 10:34 PM   #9
Longhorn Man
Post
Looking at my schematics, that makes no sence at all.
Where did you get this information at?
Old 04-14-2002, 08:11 AM   #10
71Chev
71Chev's Avatar
Post
To use a internal reg alt you still hook up all the wires at the alt. Hook the ground to a case screw and then convert from the square connector to the newer flat style,(wires still go on the same sides,just different connector). And jumper the wires at the old ext reg harness plug like the pic longhorn posted.
There is a place called AlterStart on ebay that sells high amp alts at a reasonable price. I just bought a 135amp from them. Couldn't be happier.
I have no idea how to install a One Wire Alt.
  • 71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
[This message has been edited by 71Chev (edited April 14, 2002).]
71Chev is offline   Reply With Quote
Old 04-14-2002, 08:58 AM   #11
Dandeluxe
Dandeluxe's Avatar
Cool
THAS FOR ALL YOUR INFO. I THINK IM GONNA BUY THAT ALT. CONVERSION FROM YEAR ONE PART NO. HU30 $13.50 AND GO WITH A HIGH OUTPUT ALTERNATOR
Old 04-14-2002, 11:13 AM   #12
Als454
Post
I got this wiring information from the november 1993 issue of Car Craft Magazine
(Page 75)
Old 04-14-2002, 02:53 PM   #13
Longhorn Man
Post
interesting. I'll have to look at my schematics some more, they are usually right, although, electrical upgrades seem to be hit and miss with them. (I'm a dedicated Car Craft reader) They way they tell you to wire HEI is crazy.
