Old 08-08-2005, 08:48 AM   #1
GloryHound
Working on a Nova.
GloryHound's Avatar
FS: 305 casting # 361979 and 2 350's
I am selling a 305 V8 engine for $100.00 with a casting number of 361979. Local pick up only. I may be able to deliver locally for some extra money. The engine ran good when I removed it two years ago. I have no idea as to how many miles are on it since I pulled it from a 69 GMC and these engines did not come in this year. It comes with heads, a two barrel intake, two barrel carb, water pump, flex plate, harmonic balancer, and tin.
I also have two 350 2 bolt main complete blocks in unknown condition.
One looks like it may have blown a ring is for $75.00. It still spins good. comes with heads and tin. I think the water pump is still on it but not sure if it is it goes with it also.
The other turns but i have not removed any tin to look at it nor have I ever tried to turn it over. It was in a 71 chevy truck and the casting number does not match up so the mileage is unknown. Take $100.00 for it and it comes with Heads, two barrel intake, two barrel carb, water pump, flex plate, harmonic balancer, and tin.
GloryHound is offline   Reply With Quote
