08-21-2005, 01:20 PM | #1 |
Posi Case 67-72 12 Bolt Truck 3:07-3:40
This is a nice posi case for 67-72 12 bolt truck. This case fits 3:07- 3:40 gears. I would recommend that the clutch discs be replaced or at minimum tighten up. $125 plus shipping.
08-21-2005, 02:26 PM | #2 |
Carriers
PM sent on carriers.
08-21-2005, 04:24 PM | #3 |
So what else would a person have to buy in order to use this to turn a non posi 3.08/3.07 into a posi?
08-21-2005, 08:04 PM | #4 |
Install a new set of carrier bearings on the posi case. Transfer the ring gear to the posi case. Install, set the back lash and carrier bearing preload (shims). Basically you remove your non-posi case and install the posi case!!! Thanks, Dan
08-22-2005, 03:32 AM | #5 |
ttt
08-23-2005, 05:52 AM | #6 |
ttt
08-25-2005, 01:40 PM | #7 |
ttt
08-26-2005, 04:27 PM | #8 |
3:07-3:40 posi-case
pm sent. later-johnny
