Old 09-07-2005, 07:37 AM   #1
mvpco
Cruise Control Pics installed
Hi All!
Any pics of Factory cruise control installed, especially the engine compartment? for 1972 I have some cruise master transducers and need to see placement on fender well.
Jeff Smith
Pensacola, FL
mvpco is offline   Reply With Quote
Old 09-07-2005, 11:09 AM   #2
72 longhorn BB
72 longhorn BB's Avatar
Mee too please
I have come accross some cruise parts, but am missing the transducer, and am strill wondering what is correct for installation.
I heard it was never factory installed, but there was a GM accessory kit which probably specified where to put the parts.
I have some pictures I collected of the parts ( lever, harness, etc) if you want to vieew them. Just let me know.
72 longhorn BB is offline   Reply With Quote
Old 09-07-2005, 11:25 AM   #3
chipflyer
chipflyer's Avatar
Here are part of the original install directions. I have another sheet at home that shows where to actually drill the holes I will post it tonight.
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 09-07-2005, 12:14 PM   #4
cwilkie
Chance
cwilkie's Avatar
Cruise
I have a complete cruise setup but not the instructions so please post more when you get time.
Chance
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 09-07-2005, 01:04 PM   #5
72 longhorn BB
That's sooooooooo blink'in AWESOME!!!!!!!!!!!
Thanks SOOOOOO much for the diagrams. this will really help us. BTW - I have the stalk switch and the transducer, but I need a servo. can anyone tell me if they have a working spare to sell?
Old 09-07-2005, 01:42 PM   #6
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
I have one fatcory set-up on my 72 still on my truck...it's on a 402, but will that help?
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 09-07-2005, 01:56 PM   #7
RPOZ11
RPOZ11's Avatar
pics....
Cc
HO72 build :
2017 SS
Old 09-07-2005, 01:57 PM   #8
RPOZ11
RPOZ11's Avatar
pic
Cc
HO72 build :
2017 SS
Old 09-07-2005, 01:59 PM   #9
RPOZ11
RPOZ11's Avatar
Cool
Mine is so original; I wonder if there is anyone out there that can service and re-build these so that it is restored correctly?
The diaphram boot inside I think usually breaks, like on Tri-power set-ups.
I am going to have to be really careful when I remove this thing!
HO72 build :
2017 SS
Old 09-07-2005, 02:33 PM   #10
cwilkie
Chance
cwilkie's Avatar
700r4
Has anyone ever installed one of these with a 700r4 behind a big block?
Chance
BB 396 w/TH400
BB 496 w/TH400
Old 09-07-2005, 03:08 PM   #11
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
That looks to complicated, just put a brick on the gas pedal.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 09-07-2005, 05:05 PM   #12
RPOZ11
RPOZ11's Avatar
Cool
Chance
The CC cable usually is either right below the gas pedal cable's stud on the linkage arm and having the extended stud out about 1/4" past that.I would need to look again but I think yes it is possible! Yes!
I always think of a loaded C10 700R4 with CC on 82-86 Chevy V8 applications!
Caprices are very similar!
I usually base my application upgrades on these!
The CC stud stands out farther than the studs for the gas pedal cable and the TV cable. This gives you a better connection for instalation needs!
GM thought that one out well!
HO72 build :
2017 SS
Old 09-07-2005, 08:46 PM   #13
72 longhorn BB
Anyone got a spare manifold bracket / cable?
This is all really great info., but can I ask if someone has a manifold bracket and secont throttle cable to the servo the want to sell?
Old 09-07-2005, 08:49 PM   #14
RPOZ11
RPOZ11's Avatar
Manifold bracket? The one at the rear of the carb for the cable?
HO72 build :
2017 SS
Old 09-07-2005, 11:17 PM   #15
chipflyer
chipflyer's Avatar
Here are the rest of the install directions, happy to share them. Sorry for the crappy sized images, hopefully they will help.
Jeff
Old 10-09-2005, 04:59 AM   #16
72jimmycst
I just took one off my 72 marked "dana" could this be factory? The box with the speedo cables is more of a rectangle than in the pics but every thing else looked the same.
72jimmycst is offline   Reply With Quote
Old 10-09-2005, 09:56 AM   #17
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Do any of you have the speedo cable from the treansducer to the speedo head?
Old 10-09-2005, 01:47 PM   #18
RPOZ11
RPOZ11's Avatar
Cool
yes! its still assembled on my truck...did you need a pic of it?
HO72 build :
2017 SS
Old 10-09-2005, 02:35 PM   #19
Longhorn Man
Well... actually I need one...I shoulda said that.
Old 10-09-2005, 06:11 PM   #20
Bob Moore
Dana
72Jimmy - I believe the units marked DANA are aftermarket. I have several of them on 73 & up trucks. I also see them on Chrysler Corp pickups and vans. I don't normally look at F*rds so I couldn't tell you about them.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 10-09-2005, 07:43 PM   #21
72jimmycst
will this work?
Old 10-09-2005, 08:36 PM   #22
Longhorn Man
How long is it?
Also, can't tell from the pic, is one end smaller than the other? (the part that you spin on)
Old 10-09-2005, 08:48 PM   #23
RPOZ11
RPOZ11's Avatar
Question
LongHorn DUDE:
What is the direction on this that you are trying to achieve?
Do you need a cable?
so that you can find one in a yard or something????
HO72 build :
2017 SS
Old 10-09-2005, 08:52 PM   #24
Longhorn Man
No, I need one for my truck.
The short cable on mine snapped a couple weeks ago at the begining of a road trip.
Old 10-09-2005, 09:20 PM   #25
RPOZ11
RPOZ11's Avatar
is it the cable you need? or is the jacket housing broken too?
HO72 build :
2017 SS
