Old 03-21-2002, 02:19 AM   #1
neonlarry
neonlarry's Avatar
Post Air Cleaners
With the stock intake manifold or an Edelbrock performer and and HEI what air cleaners will or won't fit? I read that normal 14'' ones do not. I plan to swap to HEI soon and I need to know if I should order an air cleaner too.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-21-2002, 03:14 AM   #2
daveo68
daveo68's Avatar
Post
I'm getting ready to do this myself and would like to know also.
Dave
68 C-10 Custom LWB
307 V8
Three-on-the-tree
Lexington,NC
davideowens@lexcominc.net
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
daveo68 is offline   Reply With Quote
Old 03-21-2002, 04:38 AM   #3
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
Post
if you are swapping over to HEI you will need a air cleaner for HEI setup as the points style rubs on the cap for now I run mine without and air cleaner( I know I know what can I say I'm cheap) but will be getting one when I wswitch to q-jet
My CANADA includes BEAVER!!!!!!!
[img]http://communities.msn.com/_Secure/0NwAzABASh!uohRSfISjhQyAQFlB*NewhOUaHR6bv*u3evbZdsgR9IvkX4X4GCQKh*KzIWBO9**DLq1ZpIJppCQ/Chevy_anim(1).gif[/img] 71 Custom/10 lb fleet .040 over 350/
burlinator2000@hotmail.com
Richmond,B.C.
[This message has been edited by Burlinator (edited March 21, 2002).]
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
Old 03-21-2002, 06:53 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Eldebrock has a round 14 inch raised airvleaner that will work with HEI. It is in the Signiture series.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 03-21-2002, 10:28 AM   #5
slam33
slam33's Avatar
Post
get an offset base for the air cleaner. Mr Gasket, Moroso, lots of those guys have them. It moves the air cleaner forward.
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
</A>
slam33 is offline   Reply With Quote
Old 03-21-2002, 10:55 AM   #6
nevada70chev
Post
got an hei with edelbrock manifold, sp2p (later to install a performer manifold) and carb (1406). i run a stock air cleaner (for now) with a 3-4 inch riser. it clears just fine. soon to get a k&n.
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline   Reply With Quote
Old 03-21-2002, 11:05 AM   #7
popeye72
Post
Ya might have to get a spacer to put under the air cleaner so it will clear the HEI. I had to put one on mine.
72 Custom, 400SB,T400,PS,PB,AC Chesapeake, VA
popeye72 is offline   Reply With Quote
Old 03-21-2002, 11:10 AM   #8
mtdave2
newly minted old timer
mtdave2's Avatar
Post
am i missing something? i have put hei in several trucks with stock air cleaners. never any trouble, didnt even think about it before
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 03-21-2002, 11:33 AM   #9
Jesse 67 c-10
Jesse 67 c-10's Avatar
Post
I've got one of those edelbroke pro flo 1000 series ones, their triangular with a kind of wire mesh on top, no clearance probs, it's cheap, re-usable and I like the looks, doesn't hide your entire engine. Just my 3 cents though
Jesse
Near Saskatoon, Saskatchewan, Canada. 67 c-10, Long fleet, Newly swapped front disks, 5 lug rear end, 327 v-8 with Vortech heads, edlbrock performer rpm air gap manifold, 1406 carb and comp XE 256 cam. Backed by a getrag 5 speed and 1 piece driveshaft. Finnally running, almost driving! www.geocities.com/chevy67jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 03-21-2002, 11:51 AM   #10
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
those can catch on fire.....
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 03-21-2002, 12:09 PM   #11
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Post
Yep! I seen 2 cars runnin that triangle air filter burn to the ground after it backfired
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 03-21-2002, 12:11 PM   #12
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
Post
The raised air cleaners will possibly have hood clearence problems. With my 6 i have a 4 barrel and 14" air cleaner with 4 element. My hood barrly fits, but it works fine. Those edelbrock proflows, the foam will get sucked in to the carb after a little use. Thats my experience.
67 Chevrolet LWB with rebuilt 292. 415 ft. lbs of torque, 4 speed, 3.73 Posi, straight and almost painted.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 03-21-2002, 12:15 PM   #13
busterwivell
Post
I've got an HEI in my 402. I have the spacer on top of my Carter, and have a 14X3 K&N with no problem.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 03-21-2002, 12:19 PM   #14
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Post
How ya like my spacer. [img]http://communities.msn.com/_Secure/0MgAAAGYQOIaXblyw3*eyO*MtDVLOV2sCVpWQv688nAx*lrrPLyehIxTjpMGREkZeopNVAaqx4bkCjRN537zDXg/TMP10.jpg[/img] Sorry had to do it. Oh and I have no problems clearing the HEI. hehe. The stock hood will actually close no problem even with all that stuffed in there, but I got a cowl hood anyway, just for the COOL factor. hehe. Later
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 03-21-2002, 12:59 PM   #15
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
Slick engine!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-21-2002, 01:00 PM   #16
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
Neonlarry,
Try an oval lid. Works great!
Jim
Old 03-21-2002, 02:14 PM   #17
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
i have an HEI and ran the stock air cleaner with the stock 3-4" spacer in between it now i switched to edelbrock performer intake, and a edelbrock signature seris air cleaner (it seems light it has a SLIGHT drop base) it clears the HEI just fine but the base hit the electric choke on my Qjet so i used the stock 3-4" spacer but it would work PERFECT with a 1" spacer which edelbrock sells for 10 bucks....
oh anthor thing i just remember i have a 1" carb spacer which could make a diffrence
My Truck pictures
64ImpalaSS 327
Old 03-21-2002, 02:30 PM   #18
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
My Truck pictures
64ImpalaSS 327
Old 03-21-2002, 02:39 PM   #19
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
most aftermarket chrome air cleaners will fit, i have a 14" chrome cleaner on mine(no idea what brand, came with the pickup). If you're wanting a stock look, grab an hei cleaner from like a 75 pickup or something.
'72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
67 Cutlass convertible
330, 3spd stick
90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 03-21-2002, 03:51 PM   #20
meathead95
computer illiterate
meathead95's Avatar
Post
I have a edelbrock 14 inch air cleaner on mine and it fits fine.
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 03-21-2002, 06:07 PM   #21
pinky350
Post
K&N 4" tall 14" dia
pinky350 is offline   Reply With Quote
Old 03-21-2002, 07:57 PM   #22
Jesse 67 c-10
Post
Awww sh$@! really? I sure wouldn't want my truck to burn up. You would think a company like Edelbrok would figure for something like that happening and fix it. I liked that thing too!
Jesse
Old 03-21-2002, 08:13 PM   #23
69 longhorn
Post
NSANE68.....I like that spacer!!!!!
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-21-2002, 09:24 PM   #24
BIG ORANGE
BIG ORANGE's Avatar
Post
Heres mine,mooneyes and k&nAttachment Converted: "C:\Program Files\Internet Toolkit 4.2\download\MVC-007S.ZIP"
BIG ORANGE 1971 SUBURBAN
1970/90-Little Buck's Truck (ONE DAY)
USED TRUCK PARTS 4 SALE
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 03-21-2002, 09:25 PM   #25
BIG ORANGE
BIG ORANGE's Avatar
Unhappy
Sorry havent figured it out yet.
