Old 03-21-2002, 11:06 PM   #1
72gmcshorty
72gmcshorty's Avatar
Question frame notching and rear axel allignment???
When doing a frame notch such as insane68's, would you need an adjustable panhard bar to keep the rearend in line? If you put airbags under such a large notch, wouldn't the raising and lowering put the rear out of allignment? i hope this is clear enough. Any ideas?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 03-22-2002, 12:01 AM   #2
Slammed67
Progress = 0%
Slammed67's Avatar
Post
Yes, if you lowering a truck, you'll need an adjustable panhard bar. Lowering a truck won't cause the rear end to shift out of center any more than a truck at stock height. You just center the rear end at ride height. Actually, with my setup, the panhard bar is close to horizontal at ride height, so the side to side movement will not be much at all.
Current project: 1967 GMC shortbed/fleetside, 350/700R4, air bag suspension. Other vehicle of interest: 1957 Chevy Bel-Air 4dr hard top, 283/powerglide, lowered 3-1/2" in front and 2 inches in the rear.
Web Site: jaySpot.com AOL Screen Name: Slammed67GMC Location: Kansas City, MO
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
