10-10-2005, 05:35 PM | #1 |
oops shouldnt have cut this
I took the front springs out of my71 C10 454 combo wanting to lower them. I have drop spindles not installed yet and saw that the top of tire to fender edge was about 6 inches. So I thought cut 2 full coils out off from stock should be close. I was experimenting.
Oops lowered it to about 2 1/2 inches to top of tire and I dont have my drop spindles in yet and the front is real bouncy. And when I jack it up off the ground the springs come loose and fall out of place. So dont do what I did. Just so I know next time. How much if any can a person cut off a stock spring to lower it without comprismising the spring and ride quality. Thanks, Rich |
10-10-2005, 05:52 PM | #2 |
senior member
one full coil
69 GMC bagged |
10-10-2005, 06:33 PM | #3 | |
User #12137
10-10-2005, 06:43 PM | #4 |
The LuvShack Garage
In my old 70 we heated them all the way around until they touched coil
to coil like a slinky, had to cut all the snubbers out, but the truck looked wicked, only bad thing is it road kinda like log wagon when you drove it.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 10-10-2005 at 06:43 PM. |
10-10-2005, 06:48 PM | #5 |
i read 2 coils and my jaw dropped. 1 as you know by now is the limit.
10-10-2005, 11:14 PM | #6 |
Saving 1 truck at a time!
I cut two coils and with the a 283 and stock spindles it is NOT low enough. Mine rides fine but I will still be going to spindles and bags to get it where I want it. If you want a set of stock small block springs, I have an extra set. With a big block on stock small block springs and spindles it may be low enough for you...all depends upon on how low you want it.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
10-10-2005, 11:20 PM | #7 |
how much does 1 coil get you? Can you do 1/2?
-Steve |
10-10-2005, 11:40 PM | #8 |
blood type; Retumbo
I dont suggest 1/2 coils. they need to sit in the pocket a certain way.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
10-11-2005, 03:23 AM | #9 |
stllookin,
Do you know if 6 cyl springs are the same as sb. I have a spare 67 c10 with stock springs. I am looking for 3 1/2 to 4 in drop in the front. I have the 2 1/2 drop spindles what spring option would work best to get another 1 1/2 with a Big Block. Also anyone know if 77 vintage springs fit our 67-72 trucks or are they different???? |
10-11-2005, 04:46 PM | #10 | |
And DON"T cut half coils. Through experience, the top of the springs will move around and make popping noises with a 1.5 coil cut.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
10-11-2005, 05:55 PM | #11 |
Keepin an eye out
Springs? We dont need no stinkin springs
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
10-11-2005, 06:29 PM | #12 |
The six is heavier than the small block v-8 so they will probably raise it. Cutting one coil lowered me about 2 inches with my small block. boraxman...bags are much better and adjustable!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 10-11-2005 at 06:30 PM. |
10-12-2005, 07:04 AM | #13 |
Watch out for your cornhole !
Yes, you can use the 77 springs. They interchange.
