Old 03-21-2002, 07:52 PM   #1
72gmc1/2ton
Post two alternators pros-cons
what are the pros & cons of having two alts. i really have nothing on the truck that needs anything extra, but i was thinking it might give more consistant voltage having two of them.
72gmc1/2ton is offline   Reply With Quote
Old 03-21-2002, 10:04 PM   #2
Brad69
Crash Test Dummy
Post
One good one will beat two bad ones any day....
The voltage consistency is a function of the regulator.
The more hair i lose, the more head i get.
Build Sheet:
1969 C-10 short fleet
Constructed by taking a 3/4 ton rolling frame from one truck, adding a rust free AC Cab from another, then a bed from another, 1/2 ton front suspension & brakes from another,add in one Goodwrench crate 350, painted DuPont Arctic White,and driven daily.
Brad69 is offline   Reply With Quote
Old 03-21-2002, 10:42 PM   #3
bigjimzlll
bigjimzlll's Avatar
Post
yea..i dont think the possable advantage..(what ever that might be) would be worth the H/P it would cost. and one more thing to break
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-22-2002, 01:04 AM   #4
nroden
nroden's Avatar
Post
I don't see a whole lot of point in it. Especially in a truck without a whole lot of stuff. For consistency check the voltage regulator. Get one of the more expensive $40. Not one of the integrated, sealed up cheap $14 ones. They burn out real quick.
Also you could get an alternator that produces more power.
Nick Rodenberg
Wellington, MO
http://nickrod.port5.com
You can click on "My 72 Chevy Truck"
I have a 72 Cheyenne 10 with a V8 350 and a TH-350 auto-tranny.
White/Ochre/White
Runs well... working on body.
Hoping to have completed in March when I turn 16
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
