11-11-2005, 11:08 AM | #1 |
Please help, I need some advise!
Hello everyone, I have bought a 1996 chevy camaro z28 and would like to use everything on my my 1956 chevy pickup. Can i usethe rear end, engine (LT1,transmission(automatic). I am trying to get as much information as possible to see if this swap is possible and if its even worth all the hard labor. Also, can i use the front suspension components on my truck, i know people have used older model 78 camaros front clip, can i use any of the front suspension components on my trucks. Thanks everyone and keep truckin!
Last edited by a417latino; 11-19-2005 at 04:28 PM. Reason: Not that many responses |
11-14-2005, 12:28 PM | #2 |
polishing a turd
Re: 96' camaro in 56' pickup?
you can use evrything except probably the fron suspension. measure the real axle, it may be too wide. the lt1 in the camaro is a nice motor though.
11-19-2005, 04:28 PM | #3 |
Thanks 1-ton of fun, anyone else have any input on this setup?????
12-15-2005, 07:49 PM | #4 |
I would measure the rear axle as well. Run a tape between the inner wheel wells under your bed. you may be able to use your rear axle with the right wheel offset. I wouldn't attempt the front end swap because it is way to easy to install a mustang II or something else. If you are dead set on using it measure the frame width and see if they are even close. I doubt that they are but free is always better....As far as motor and everything else you may need to extend your factory harness in places but I have to many rods running that motor and tranny combo to say that it cant be done relatively easy.
Keep us posted! Todd |
01-14-2006, 05:47 PM | #5 |
you should be able to use everything, but like 1tonoffun and todd55 said, measure the rear axel, but you should be able to use it.
01-15-2006, 11:54 AM | #6 |
Sounds good but lots of work adapting the front and rear end in.
The Specifications on the 1996 Chevrolet Camaro are: Length 193.201 in | 4907.3 mm. Width 74.101 in | 1882.2 mm. Height 51.301 in | 1303 mm. Wheelbase 101.101 in | 2568 mm. Front Track 60.701 in | 1541.8 mm. Rear Track 60.601 in | 1539.3 mm. Ground Clearance 4.501 in | 114.3 mm. Cadman
56 GMC 1922 Dodge Rat Roadster 89 Gray Allante 90 Red Allante Turkey Run Photographer http://www.turkeyrun.com/photo_gallery.html |
01-15-2006, 01:51 PM | #7 |
The 4th Gen Camaro is unibody, right? If so, you will need to make or buy a crossmember to adapt the front suspension to your frame.
