Old 12-04-2005, 02:39 PM   #1
MrBinAz
MrBinAz's Avatar
Door lock question....
Seems kinda like a silly question, but I've become so used to new cars that my memory of older vehicles has posed me with this question:
I remember the old days as.....
locking the door by pushing the pin down and closing the door....done...door locked.
Now days....you lock 'em with the key after closing the door....I guess to prevent leaving the key in the ignition.
On my '72 , are the door locks supposed to work by pushing down the pin/post on the inside and then closing the door? (doesn't work like that now) or locking the door with the key lock from the outside (sorta works like that now but having key/tumbler issues).
<<<<me.........ready to be schooled
-----the fleet-----
'72 K20 Chevy Suburban
'72 Datsun 510 (vintage racer)
'89 Honda Civic Si HB
'89 Honda Civic Dx HB
'08 Honda Element EX-P
'78 Honda Express (50cc. pit-ped)
pix here
MrBinAz is offline   Reply With Quote
Old 12-04-2005, 02:59 PM   #2
matapalo
Re: Door lock question....
I've always had to use the keys to lock the doors on my '72 suburban. I'm pretty sure thats how they were made to work but then again I've always had problems with sticky/hard to turn doorlocks.
It's actually quite an ordeal to lock my burb up; I carry around a rock (hand picked from the bottom of Canyon De Chelly) and a pair of pliers (antiques from my great-grandfather's collection) to pound the pin down and pry it up again because it sticks so badly. I suppose one of these days I'll have to get around to fixing it...but then I'd miss the rock and pliers so...
1972 3/4 ton 4x4 Suburban
1978 Chevy Luv
1967 Ford Mustang Conv
matapalo is offline   Reply With Quote
Old 12-04-2005, 03:30 PM   #3
Frizzle Fry
Frizzle Fry's Avatar
Lock with key after closing the door. Locking before closing will cause it to pop up.
Frizzle Fry is offline   Reply With Quote
Old 12-04-2005, 03:56 PM   #4
MrBinAz
MrBinAz's Avatar
Ok.......so it appears that I have a lock/key issue on the drivers side door only.
The passenger side and rear cargo door work good.
What can I do? Is the lock repairable? Figure the key is OK since it works on the other locks.
Hate to end up with having to buy new locks.
Thanks guys.....
-----the fleet-----
pix here
Old 12-04-2005, 03:58 PM   #5
MrBinAz
MrBinAz's Avatar
Oh.....another thing.....I'm not crazy right? They did make cars that could lock the old way right? Push the pin and close the door.....locked.
-----the fleet-----
pix here
Old 12-04-2005, 05:11 PM   #6
Frizzle Fry
Yes there are cars that lock that way. I wish ours did. If your key won't turn in the drivers side only, that door cylinder may have been replaced. It could also just be frozen. With your inner door panel off, the cylinder comes out by removing one clip. Take it out and lube it up. Worste case, take it to a locksmith.
Old 12-05-2005, 02:03 PM   #7
Scrubby
Check out GMTrucks.org
Yep. Actually in 73, GM changed the trucks to do this same thing. It is a pain, but I have never locked my keys in the burb.
Scrubby is offline   Reply With Quote
Old 12-21-2005, 10:59 PM   #8
skeeter288
the door locks in my 68 panel work like yours. i don't worry about it. you can't lock yourself out thatway. if it really bothers you, get an aftermarket power lock kit and install it . i installed one on my dakota and it works great. once i get a good set of doors for my panel thats what i'm gonna do.
skeeter288 is offline   Reply With Quote
Old 06-07-2006, 04:44 AM   #9
ol' truck
~one mean a$$ truck~
ol' truck's Avatar
man.. I was wondering about this.. I thought only honda and some newer cars did it.. nice..
ol' truck is offline   Reply With Quote
Old 06-07-2006, 04:37 PM   #10
bagged91
Out draggin'
bagged91's Avatar
The reason your door is having difficulty locking could be one of these 2 reasons...
#1) Your door latch is "sticking". Soak it with CRC or WD-40 or Tri-Flow. I actually removed mine from the door(it broke). I soaked the crap out of the new one, got the catch to spin nice & free and I greased the contact surfaces. After reinstalling, it works fine and locks with just your fingertip on the key. The lock cylinder had nothing to do with it...
#2) Your door is out of alignment. You may notice that you have to push, pull or jiggle your door to get it to lock. Again, that is because the dogleg in the catch isn't engaging.
This is my experience with the locks on burbs. Also, I found out it's really fun to put it all back together with the glass in...
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
