Hey guys, I'm trying to install disk brake front end on the original spindles of my '48 chevy 1/2t pickup. The kit I bought from CPP came with adpts to install the new roller bearings onto my spindles , but the only problem is they wont go on all the way. I have tried heating the adpt , sanding the spindle,putting the adpt. into boiling water for appx. 5 min. (like the instructions say)but no go all the way. it stays about 3/8" from seating on the spindle. Any suggestions? I'm all ears!!!!! Thanx
Hollister Road Co.
Re: roller bearing spindle adpt.
does this happen on both sides?
you may try wrapping the spindle in a cold pack like the ones you get from a pharmacy for knee injuries, heat the part in an oven to about 350 take it out wrap it in a cooking glove and carry it out to the truck quickly take off the cold pack and try to push on the spacer. the cold pack and 350* are well within the heat range of those parts. unless the MFG says something to the opposite. |
Street Rod Dreamin'
Location: Work:Batam, Indonesia/ Home:League City, Texas
Did you give CPP a call? They were there today. Their tech support did a good job for me recently.
1954 Chevy 3100 Panel Truck 2004 GMC Yukon 2007 GMC Sierra 4X4 "I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it." Benjamin Franklin, On the Price of Corn and Management of the Poor, November 1776 |
It's a catastrophic success.
![]() Join Date: Jan 2003
slide a foot long piece of pipe that just fits over your spindle,it will even out the drive of the hammer blows.
Hmmm, I put just the roller bearings on my Burb last fall and they went on easily as I recall by heating the race with my propane torch. Just can't let it get too hot, don't let the metal change color in other words.
AD's Rule!! 53 GMC Suburban--48 GMC 1/2 Ton project--49 Chevy Pick-up--52 Chevy Pick-up (my driver) ![]() |
![]() ![]() btw if anyone buys the leaf spring and shock kit to install your new open shaft rearend and convert from lever to tube shocks, from www.truckandcarchop.com, make sure you also order the lower shock mount bolt because they do not come w/the "kit" thought I'd save you a little running around or digging in the sacred bolt bucket. ![]() |
