Old 03-21-2002, 10:09 PM   #1
Tim Christian
Tim Christian's Avatar
Smile HEI ?
Well I just put the power steering on the daily driver today and like WOW why did I ever wait this long anyway going to put the HEI in next but I have a couple of questions what guage wire should I run for the 12 volt source? What is the best wat to put it in so I don't get it 180 out? Also should I get plugs and plug wires for the HEI? Thanks
67 GMC Stepside(UNDER CONSTRUCTION)
67 GMC Custom
67 Chevy C-30
Tim Christian is offline   Reply With Quote
Old 03-21-2002, 10:30 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Post
I think I ran a 12 gauge wire. Some guys put an inline fuse in. I'd get hotter plugs and gap them per HEI specs and get the HEI wires. I just found TDC on #1 compression stroke and followed firing order from there. Made a noticable difference.
Jeff Jesseman
Cheyenne Parts Northeast
Franconia, NH
67 Chevy SWB Fleetside
70 GMC Burb 1/2 ton 2wd
72 Chevy Burb 3/4 ton 4x4
Parts bought and sold
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-21-2002, 10:36 PM   #3
bigjimzlll
bigjimzlll's Avatar
Post
I ran a #10 wire to the ignition spot on the fuse panel....lol...about 180 out..im only right 50% of time
67 lwb fleetside...first hotrod in 25 years...283..186 bowl ported heads..270h comp cam 600 1405...stealth intake..HEI..th350 with 2500 rpm stall..4:10 POSI
god I love to go fast
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-22-2002, 12:23 AM   #4
StingRay
StingRay's Avatar
Post
Tim you can make sure you don't get it 180 out a number of ways. If the engine already has a dist then line up the new HEI so that the rotor points to exactly the same place as the old one did and then make sure all of your new wires (you have to use HEI style wires with an HEI cap)are in the same orientation as the old ones. If the old one is already out and you need to get the new one in right just pop out the #1 spark plug and hold your finger over the hole. Crank the engine over with a socket and ratchet until you can feel compression trying to pop your finger out of the hole. Line up your timing mark to zero and then install your new dist with the rotor pointing to where your #1 wire is going to be on your cap. I use at least 12 ga when I wire these and I usually find a donor harness to rob the connector pin out of so that I can re-pin the stock fire wall connector to take a 12 ga wire right at the connector block in place of the factory ignition lead. You can not use the factory dist power lead that runs to the coil as they are resistance wire and only about 9 volts actually gets to the coil during normal operation. I have always just used plugs from like a 78 350 truck as they all had HEI's. My engines have all been pretty mild so stock heat ranges and gaps have always been pretty good. You can also determine TDC compression by observing rockers or lifters on #1 cyl and when both valves are rocking (closed) line up your timing mark. I hope this helps.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 03-22-2002, 06:04 AM   #5
Tim Christian
Thumbs up
Thanks Guys! It is great to have smart family members.
67 GMC Custom
67 Chevy C-30
Old 03-22-2002, 07:55 AM   #6
StingRay
StingRay's Avatar
Post
Oh ya. You can turf the wire that runs between the starter and the old dist. It isn't used with the HEI.
Canada
