Under floor Brake Booster and Clutch pedal??? Can it work?
Anybody made this combo work? Any tech articles or threads on the topic would be great. Thanks Jim
Re: Under floor Brake Booster and Clutch pedal??? Can it work?
yes ive got the brake booster relocated under the floor on mine, these are not close up pics of it but you get the idea
![]() ![]() ![]() its a 79 camaro front clip sorry its dirty because I was block sanding today but it doesnt go back to where the brake booster is actually mounted ill get a close-up pic of it for you tomorow. Last edited by 55ChevyPU; 01-27-2006 at 09:48 PM. |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Nice Start there 55!
#4 | |
Son Of Gravel Man
Try Classic Trucks Mar 06 article Franken Brakes
they install this http://www.abspowerbrake.com/AbsCatalogPag039.html More info on them http://www.abspowerbrake.com/ElectricHPpage.html
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
Here's what I have on my truck. It is TCI's power brake unit. It comes with a 70's style Corvette master cylinder and a 7 inch booster. The bracket bolts to the original spot on your frame you just have to drill one hole for the top bolt. You will also need to use a new style proportioning valve and residual pressure check valve. With this type of setup, gravity and vibration cause the fluid to leak back to the master cylinder causing a loss of brake pressure and a longer pedal stroke. Basically, not having this check valve can cause your brakes to give out. I bought my set up off of e-bay from FatRodder or Cpp also sells this setup. Good Luck!
![]() Last edited by CAL 58 GMC; 01-28-2006 at 02:56 PM. |
ive basically got what 58 has, literally the same frame
I have the CPP unit and I want to make it work with a stock clutch pedal and a manual T-5 trans. Anybody have experience with this? Please let me know, thanks Jim
