07-20-2002, 09:43 PM | #1 |
Wanted A/c stuff
I need the whole deal, the entire Air Conditioning setup on the outside of the cab. Whatever you've got as long as it will fit on a '74. This setup was from an '80 GMC. I have the compressor and the little radiator but the housing on the firewall smashed when the cab was lifted off the truck. Also need the heater control for A/C. Thanks.
07-23-2002, 08:42 PM | #2 |
Member #1049
I have most of that crap of a 73 i parted.I wont be home until the 28th of August,73 up parts CHEAP want them all gone!!!!actually all parts will be leaving.
07-23-2002, 09:44 PM | #3 |
I'll take them all. What do want for them? I'm really in no hurry since I need to get it painted yet. I also need some ducting for in the inside. Whatever you have I'll unload. What is your address? Thank you.
07-23-2002, 09:47 PM | #4 |
A/C Parts
If Livrat can't help you out, I have a complete set-up for an A/C system. Compressor, condensor, controls, heater box, harness. Please email me at alex.bush@encompass.com if I can help.
07-23-2002, 09:50 PM | #5 |
Sounds good, I also need the dash bezel and dash pad vents in woodgrain if possible. Thanks
