02-24-2006, 08:26 PM | #1 |
turn singal switch info need
was wondering if any could tell me how to install a turn signal switch ina 71 c-10 i know its not hard just any help i thank you now
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
02-24-2006, 10:32 PM | #2 |
Re: turn singal switch info need
1. remove steering wheel with a steering wheel puller
2. unscrew it with a phillips, just 1 screw |
02-24-2006, 11:03 PM | #3 |
After you remove the steering wheel you have one screw in the turn lever, one in the flasher button, and three in the switch. Unplug wires and feed up through the bowl. GOOD LUCK!!! Gary from Charlotte
02-24-2006, 11:11 PM | #4 |
okay anyone knwo a good place to get a compelete turn switch advance auto wants 27 but the picture on there site dont have the hazard button and i need one of them too http://www.partsamerica.com/ProductD...pe=832&ptset=A
or i can get one from mane truck parts for 34.95 with it what do yal think? http://www.manestruckparts.com/store...&Category_ID=8
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 02-24-2006 at 11:11 PM. |
02-25-2006, 12:00 PM | #5 |
67-72 Addict!
I got the whole kit from my local Chevy dealer. Don't forget to disconnect battery before removing switch because you have to press the hazard button in to gain clearance in order to angle it up and out.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
02-25-2006, 03:57 PM | #6 |
many vendors sell this item...it may still even be available from GM.
A good site to check out is: www.wiringharness.com
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
02-26-2006, 01:48 AM | #7 | |
