Old 03-01-2006, 02:05 AM   #1
13lazer
13lazers' blazers
13lazer's Avatar
Talking 700r4 performance
this is the 1st time i have owned a vehicle with a 700r4, i have had several th350's and th400's. i really like this tranny. it's no borg warner t-5, but i love it anyway. i've been shameing beemers, camaros, and everything else that tries to run with me. i've never had so much fun. i probably won't get more than 50000 miles out of it, i keep hearing odd chirping noises in reverse and under hard acceleration. i didn't expect much from this one because i assembled it in my basement. i know i missed something, my next one will be built bulletproof. i just wanted to offer up an opinion.
btw, the tv cable setup i got from bowtie overdrives is great, i'm very satisfied with their kit. after 2 weeks of fiddling with my tv setup from the donor truck, i was dialed in the day after i got the bto kit.
13lazer is offline   Reply With Quote
Old 03-01-2006, 12:35 PM   #2
hotrodhomi
hotrodhomi's Avatar
Re: 700r4 performance
I thought you were restoring this blazer to stock???
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 03-01-2006, 12:45 PM   #3
Bowtie67
Bowtie67's Avatar
If you havent replaced your U-Joints that might be a good idea, they do chirp like a little birdie and not just clunck when you put it in gear. Usually the chirping is due to dried out ujoints wanting to freeze up.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 03-01-2006, 01:59 PM   #4
70rs/ss
70rs/ss's Avatar
I too have a 700r4 that I dropped over $1500, and I love it. I am going for the T5 and LT1 in my 70rsss Camaro. Stock is boring. I could understand keeping a Hemi Cuda bone stock, but my Camaro as rare as it is (one of appox 5k) is still worth more upgraded. I'll keep the original numbers matching 350 w/4-speed, but I want to drive it and have fun!! Do what you want cause even a stock restored 2wd Blazer isn't worth a ton and the upgrades will bring up the value.
70rs/ss is offline   Reply With Quote
Old 03-02-2006, 07:28 AM   #5
13lazer
13lazers' blazers
13lazer's Avatar
it had a 250 cu inch/ three on the tree originally. the P.O. swapped in the 1st stroker that i blew up, and a th350. not to mention he destroyed the original wires and stripped out everything under the dash. im keeping my eye out for a cheap (free) l6/3 speed saginaw combo to put back in. i can do the conversion in a weekend with all the parts present. anything that is to be driven on a freeway in so cal needs overdrive. i need the ability to get away from the drivers who like to regulate my progress.
when i do put the three speed back in there im thinking about a gear vendor to keep my rpm's down
when it comes to starting, steering, and stopping i like to upgrade as long as no cutting is involved. power steering, power disk brakes, and overdrive are required on anything built to drive. c-notching the frame, tubbing the bed, and bagging them are what i was complaining about. a real chevy doesn't slow down for speed bumps i.m.o. anyway.
13lazer
Old 03-02-2006, 07:35 AM   #6
13lazer
13lazers' blazers
13lazer's Avatar
i never thought of that but ill check. i had both u joints changed when my driveshaft was cut for the 700r4 installation. maybe the guy forgot to lube them.
